2005 R5 2.5 TDI no DPF.
Question the first, keeping in mind that this engine requires 506.01 or 507.01.
Is it safe to use a crankcase cleaner like Seafoam in the oil to clean carbon out of the ring lands and combustion chamber keeping in mind the nikasil bore lining and high shear strength requirement for the cam.
I'm not sure about adding solvent to the oil for that reason.
Question the second. What do you think about using Liqui Moly Cera Tecoil additive to help with the cam situation?
