Monday,23,October,2023,10:36:58:58995
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVGEP9BP3DD000603 License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
69 6C 6D 72
VIN: WVGEP9BP3DD000603 Mileage: 277642km-172518miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 K HW: 7P0 907 401 K
Component: 3.0TDI FSA H17 0011
Revision: 56H17--- CVN: E7FCBDE45C3E0D045C3E0D040E1FC39E
Coding: 292A4012233600050000
Shop #: WSC 23324 444 00000
ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
ROD: EV_ECM30TDI0117P0907401K.rod
VCID: 372B24EF8FC3E382FE1-8062
VINID: 9E65D58094A00D45000001800C60B5CFBD
3 Faults Found:
5188 - Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 277642 km
Date: 2023.10.05
Time: 00:14:12
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 13 °C
Intake air temperature: 15 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 12.100 V
Unlearning counter according OBD: 40
P Flt Ld fac Ash Cor: 0.6200
Particul.filter diff.pressure: 2 hPa
Exh t Adap T Oxi Cat Ds: 19.7 °C
Exh t Adap TP Flt Ds: 222.0 °C
Exhaust gas jet volume in particle filter: 0.0 mÂł/h
5189 - Particulate Trap Bank 1
P2002 00 [047] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 277642 km
Date: 2023.10.05
Time: 00:14:12
Ambient temperature: 13.0 °C
DPF: offset for differential pressure: 1 hPa
Particle filter: soot mass measured: 24.05 g
Particle filter: soot mass calculated: 28.04 g
Particle filter: kilometers since last regeneration: 238951 m
Particle filter field regeneration: cancel conditions-Bits 0-7: 0
Particle filter field regeneration: cancel conditions-Bits 0-7: 1
5258 - Exhaust Gas Temperature Sensor 4 Bank 1
P246E 00 [175] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 277642 km
Date: 2023.10.05
Time: 00:14:09
Voltage terminal 30: 12.120 V
Exhaust gas temperature sensor 1: 28.7 °C
Exhaust gas temperature sensor 2: 27.8 °C
Exhaust gas temperature sensor 3: 19.7 °C
Exhaust gas temperature sensor 4: 1000.0 °C
Shut-off timer: last engine shut-off time: 398 s
Readiness: 1 2 0 1 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 AK HW: 0C8 927 750 A
Component: AL1000 AISIN 001 3398
Serial number: CVN: A4540B9E
Coding: 001368
Shop #: WSC 63090 001 1048576
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002_VW52.rod
VCID: 75B7EEE7D54F51922CD-8020
No fault code found.
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 M HW: 7P0 907 379 A
Component: MK25A H36 0436
Revision: -------- Serial number: 414020010EC815 Dataset Number: 7P0012v____ 7P16
Coding: 5B7613C349242553DAFAC89392D5A4407300
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 47CB542FFF2393028E1-8012
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BK HW: 4H0 907 064 BK
Component: BCM2 2.0 H32 0333
Revision: 00002001
Coding: 09860010000000000000
VCID: 73B3D0FFDBBB4FA2029-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Serial number: 0512000023605013
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 2312000103820012
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 2 Zonen H20 1305
Coding: B606200A80
ASAM Dataset: EV_AirCondiFront 004001
ROD: EV_AirCondiFront_VW52.rod
VCID: 7EA5F1CBE07912CA7D7-802A
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BL HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0111
Revision: 15012002 Serial number: 00000001337544
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120503 31 0020
Serial number: 90243400120521170321
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10388717
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000002205121003
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R12DN07
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag025 H05 0025
Revision: -------- Serial number: 003L0003E8FL Dataset Number: 7P6003v____ 0983
Coding: 000000000000000000000000000000003235
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 41DF4A37D107AD32405-8014
Seat occupied recognition:
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R12301089MT
Crash sensor for side airbag: driver side:
Serial number: 3575LRB405D1D5MSBPPG
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB405F1D5MS506C
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515RRB405718B7489FT
Passenger side rear thorax airbag crash sensor:
Serial number: 3525RRB404P18B74F9OK
Crash sensor for front airbag: driver side:
Serial number: 3555NRB400M4UE2051G5
Crash sensor for front airbag: front passenger side:
Serial number: 3565NRB400M4UE20D0RO
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LEP0004J
Coding: 000015
VCID: 363529EB88491A8AE57-8062
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0183151
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 981 F HW: 7P6 920 981 F
Component: Kombi H14 0318
Revision: 14240078 Serial number: 658250512592025
Coding: 8B7733022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: EV_KombiUDSRBVW526.rod
VCID: 40D94F33DA0DA43A4FB-8014
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 F HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H10 6028
Revision: -------- Serial number: 00000000549394 Dataset Number: 7P6067v____ 0022
Coding: 0001037500
GVL: FB0F40451D7F000000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 3B2338DFB3EBC7E21A9-806E
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650422198
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000030085187
Coding: 0058130000004001000001010101202020202121202020
VCID: 343113E39E35089ADB3-8060
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000127939530
Coding: 011D07205E00453005080000
VCID: 44D14323CE95B81A6B3-8010
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0177139760
Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 1151212846
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO1611144Z
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO1645013.
Coding: 191100
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000127799673
VCID: 3B2338DFB36BC7E21A9-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1252200183 Dataset Number: A001
Coding: 01040200
ASAM Dataset: EV_ParkbA7 000006
ROD: EV_ParkbA7.rod
VCID: 363529EB88C91A8AE57-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0009
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CA1FBC3F66500DA533-8028
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0003
Coding: 130000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156E30C7598444
Coding: 020007020000000001
VCID: 211FEAB731C78D32205-8074
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 C HW: 7P6 035 664
Component: H-BN-NA H45 0544
Revision: -------- Serial number: 445E20C7535398
Coding: 010200050040E1EE41022B0C00000003F0000100
VCID: 382927D3825DECFAF7B-806C
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9M7900ALW
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000127808286
Coding: 011C07200000253005080000
VCID: 3A2D3DDBBC51FEEA01F-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000078587 Dataset Number: 7P6096v____ 0018
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FDB4CCFA7F3DBC2361-806A
4 Faults Found:
8397058 - Front Left TPMS Sensor
C1050 31 [009] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 64
Mileage: 268337 km
Date: 2023.05.13
Time: 06:42:33
Vehicle speed: 100 km/h
Outside temperature: 18 °C
Reception level antenna 1: 700 mV
Offset level antenna 1: 650 mV
8397314 - Front Right TPMS Sensor
C1051 31 [009] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 64
Mileage: 268337 km
Date: 2023.05.13
Time: 06:42:33
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 64
Mileage: 268337 km
Date: 2023.05.13
Time: 06:42:33
8397826 - Rear Right TPMS Sensor
C1053 31 [009] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 64
Mileage: 268337 km
Date: 2023.05.13
Time: 06:42:33
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H09 0110
Revision: 5A001001 Serial number: 00000176601350
Coding: 020D000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H06000 Serial number: 525 PA8J242660
Coding: 0110001
VCID: 372B24EF8343E382FE1-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001 Serial number: 129200525 Dataset Number: 7P6959107A D043
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202137
ROD: EV_HeckkTouar.rod
VCID: 3D2736C7ADFFC9D224D-8068
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000127811258
End----------(Elapsed Time: 02:02, VBatt start/end: 12.0V/12.2V)-----------
