1 - 20 of 30 Posts
archills
Discussion starter · #1 · (Edited)
Hello Folks,
It seems my Touareg parking brake failed. dashboard has the parking brake error. and i could not release parking brake.
video: 2015 touareg 7P parking brake failure
VCDS Scan result. I cannot move the car now. Any advice would be highly appreciated.
Code:
Wednesday,22,February,2023,22:54:42:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.10.0.1
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WVGZZZ7PZFD013665   License Plate:
Mileage: 86191km-53556mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
          72
VIN: WVGZZZ7PZFD013665   Mileage: 86191km-53556miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CJMA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 A    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0001
   Revision: 53H41---    CVN: 9B85DEB6
   Coding: 292A4012232601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P1907401A 001002
   ROD: EV_ECM30TDI0117P1907401A.rod
   VCID: 2E53BBBF71174CFD20-807A
   VINID: 9E65EAAAA1E0A965000431861434DFD362
1 Fault Found:
5608 - No Communications with Steering Angle Sender (G85)
          U0126 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
   Part No SW: 0C8 927 755 N    HW: 0C8 927 755
   Component: AL1000 AISIN  130 2877
   CVN: C6F63456
   Coding: 010100011C008400000000000000000000000000
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 3C7781F7B76BAE6D9E-8068
1 Fault Found:
23198 - No Communications with Steering Angle Sender (G85)
          U0126 00 [032] - -
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 43314438062677
   Coding: 5B6B13C349252556DAFAC89992D7A470F701
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4C97D137E7CB1EED2E-8018
No fault code found.
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 FE    HW: 4H0 907 064 EE
   Component: BCM2 2.0      H36 0560
   Revision: 00002001
   Coding: 01B60010000000000000
   VCID: 71E960C3A8A913057D-8024
   Subsystem 1 - Part No SW: 7P6 959 754 AL    HW: 7P6 959 754 AL
   Component: FBSTOUAREGIDG  H08 0084
   Serial number: 0514000114118016
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H40 0046
   Serial number: 3214000188537011
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CD    HW: 7P6 907 040 CD
   Component: Klima 2 Zonen H23 1406
   Coding: 3626200890
   ASAM Dataset: EV_AirCondiFront 004001
   ROD: EV_AirCondiFront_VW52.rod
   VCID: 78FF5DE7C3D3424DBA-802C
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 22020001    Serial number: 00000986068602
   Coding: 26000014D0345D010029400300005D4C431D470827010241000000000040110000000000000000
   VCID: 6ADB77AF857FE0DD3C-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    150104  033 0021
   Serial number: 90243401150109073603
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20483113
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000000602150461
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28201421902406
   Coding: 308504
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 4487F917CF9BD6ADE6-8010
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag03F H10 0043
   Revision: --------    Serial number: 003NK002CMA6
   Coding: 000000000000000000000000000000003346
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   VCID: 4385FA0BCA95D195DF-8016
   Crash sensor for side airbag: driver side:
   Serial number: 3575LRB405R322V89PT9
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 3585LRB405R322V820NF
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 3517ARB404R30TVSF20Z
   Passenger side rear thorax airbag crash sensor:
   Serial number: 3527ARB404R30TVSR93F
   Crash sensor for front airbag: driver side:
   Serial number: 3557BRB401G52O77AIOF
   Crash sensor for front airbag: front passenger side:
   Serial number: 3567BRB401G52O76M3TH
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
   Part No SW: 4H0 953 568 K    HW: 7P6 953 507 AB
   Component: Lenks.Modul   H06 0005
   Revision: --------    Serial number: 01374OAK0000G
   Coding: 000015
   VCID: 3B7582EBBA65A95597-806E
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H05 0028
   Serial number: 0024060 TRW 20141217
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 883 B    HW: 7P6 920 883 B
   Component: Kombi         H13 0515
   Revision: 13240300    Serial number: 658210115592010
   Coding: 332731002A00000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 3D718CF3AC71A765A9-8068
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 7P6 907 530 M    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6042
   Revision: --------    Serial number: 00000001723053
   Coding: 000D07AD00
   GVL: FB4F40051D65000000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 428BFF0FD58FD89DD4-8016
   Battery Monitoring Control Module:
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 42026L22505701438504
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Component: J532_DCDCStab  H17 0042
   Serial number: 15027002896021200181
Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000134679792
   Coding: 011D0720D001451005080000
   VCID: 7AFB47EFF5DF505DCC-802E
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0358767565
   Coding: 0101163828B9008083200624000000000000000000000000000000000000
Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000134759287
   Shop #: WSC 10442 002 1048576
   VCID: 489FED27FBB3F2CD0A-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1512500336
   Coding: 01040100
   Shop #: WSC 41105 002 1048576
   ASAM Dataset: EV_ParkbA7 000006
   ROD: EV_ParkbA7.rod
   VCID: 366393DF8947743D68-8062
   Slave 3:
1 Fault Found:
0018 - Switch for Electric Parking Brake
          C100C 01 [009] - Electrical Failure
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Frequency: 1
                    Reset counter: 89
                    Mileage: 86191 km
                    Date: 2023.02.22
                    Time: 21:08:31
                    Voltage: 12.0 V
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 C    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0091
   Revision: --------    Serial number: --------------
   Coding: 01AE02000B000200
   ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3F8DF6FBA67DB575BB-806A
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B00000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B00000
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227AZ0F8530439
   Coding: 040005020100000003
   VCID: 2643439F51E704BDD8-8072
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 7P6 035 764 E    HW: 7P6 035 764 A
   Component: H-BNT-RW      H40 0816
   Revision: --------    Serial number: 445AW0F7503624
   Coding: 010A01050040C1EF01000B0E00000003F00001030000000000
   Subsystem 1 - Part No: 8R0 060 884 BN
   Component: ROW 2014  0605
   Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: DU8 SV Touch  H53 0046
   Serial number: VWZ8Z9RX700B14
   Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Subsystem 4 - Part No: 8R0 060 961 F
   Component: CD-Database  5571
Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000134345645
   Coding: 011805200001251005080000
Address 6C: Back-up Cam.        Labels: 4L0-910-441.clb
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8J4Z1338
   Coding: 0020001
   VCID: 377D9EDB464D8D3573-8062
Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000134787225
End-------------------------(Elapsed Time: 04:14)--------------------------
short summary about fix:
1. replacement of parking brake switch
2. using below guide to complete the basic settings (air gap calibration)
Million thanks to SaVAGeSoot and gazaflash again for the help.
Please save this thread and claim a beer when you guys visit Sydney one day.
Let me check my crystal ball....
No dice... Ball said do some actual diagnostics.. could be a switch, could be a contact, could be a wire, etc..... Or load the parts cannon.
Let me try to replace the switch first. Many thanks again for your great help. I was so frustrated yesterday that I could not move the car at all with this stupid parking error.
Sorry mate, I'm currently shovelling my driveway in freezing rain/sleet... check your wiring diagrams, check any related fuses, get your DVOM and test light out and check wires and circuits! Or just replace the switch and see if you get lucky, and if not, go do all the troubleshooting that you skipped.
Discussion starter · #9 ·
Sorry for the late response and I was so busy to dry my soaking wet floor carpet caused by open window in a pouring rain night.
I have taken out parking brake switch and i ordered one online based on the part number. Finger crossed it could fix this issue at least.
Why d
Why don't you test the old switch and see if it works first??
Discussion starter · #13 ·
update:
ok. new parking brake switch replacement is done.
Good news:
Parking brake switch is working fine now. it can pull brake and release brake without problem.
My car can move around finally.
Bad news:
The warning is still on dashboard and i was wondering if it would require some coding for the replacement.
Video: 7P after replacing parking brake switch
new vcds scan:
Code:
Thursday,02,March,2023,11:35:16:00009
www.Ross-Tech.com
Mileage: 86192km-53557mi   Repair Order:
          72
VIN: WVGZZZ7PZFD013665   Mileage: 86192km-53557miles
1 Fault Found:
          U0126 00 [032] - -
   CVN: C6F63456
1 Fault Found:
          U0126 00 [032] - -
   Revision: 00002001
   Coding: 3626200890
   Coding: 004DBD
   Coding: 025223
   Coding: 308504
   Coding: 000015
   Coding: 000D07AD00
   Voltage stabilizer:
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
1 Fault Found:
0024 - No Basic Setting
          B2010 00 [009] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Frequency: 1
                    Reset counter: 89
                    Mileage: 86192 km
                    Date: 2023.03.02
                    Time: 11:26:44
                    Voltage: 14.6 V
   Coding: B00000
   Coding: B00000
   Coding: 0020001
End-------------------------(Elapsed Time: 04:09)--------------------------
Discussion starter · #16 ·
You've already tried addressing what the code is telling you the problem is? :unsure:
I tried to clear error too many times. Except no basic settings error. another error will pop up later. which is like below
0025 - No calibration
B2010 F0 [009] - Deviation from expected range.
It is a bit late in Sydney now and I will scan tomorrow and post the latest one.
Thanks again for your help. Basically, the big headache is gone. just have to deal with this annoying warning.
I don't understand the approach.
The error tells you that you're missing BASIC SETTINGS...... how are you translating that into CLEAR THE CODE?
There's a BASIC SETTING button in VCDS.... did you go in there and go through the process?
You must use VCDS and complete a basic setting, which means the parking brake is functioned a few cycles by the software and it will tell you the shoes gap. If it’s 1.9 - 2.3 air gap and not 0.15mm difference between both sides then you will be able to clear the codes. you can’t clear the codes if the basic setting is not complete. Adjust the shoes and repeat basic setting cycles until it says “basic setting complete.”
Grind in procedure is a whole different ball game and is only needed when the disc/drum/ shoes and adjusters are replaced or moved.
Discussion starter · #19 · (Edited)
Thanks for putting me in the right direction. I looked basic setting after i saw the error code of no basic setting while i did not have any clue how to do it.
Is there any wiki or guide i could follow in my scenario - parking brake switch is replaced?
update:
I google searched and if this one would apply to my situation?
1 - 20 of 30 Posts
