LOL, yes but mandrill bent SS snorkels are pretty commonplace around here.
Once you have the pattern it's easy, the tricky part is:
1. getting the pattern
and 2. cutting the holes in the bodywork etc in the right place.
I guess there is not enough space to hook into the OEM filter housing, so the these guys have replaced the whole filter unit.
I'm not a big fan of pod filters, basic physics tells me the less surface area the less efficient the filter will be.
Went on a trip with a mate in a Prado, did several hundred km on dusty dirt roads mainly with the Prado in front.
after getting back home Prado mate calls me and says "check your air filter mine was chock a block with dirt".
I check my filters and they were fairly clean. We eventually figured the Prado's air intake draws air from inside the
front guard... thus the dirt load.the Touareg draws air from the front either side of the radiator.
