First off i know that there are many similar threads about this topic, but im not sure if my problem is like the related.
Ok, so i just got done driving 180 miles in the pouring rain. When i shut it off the fans stayed running at full speed sounding like a turbine . So i drive it around the block, and shut it off again, and the fans stopped. So i didnt think much of it.
So today i am driving it around doing errands and i shut it off and the fans are on again. Except this time they are at various speeds. The fans will be at full speed then settle down a little, then get back to mid speed, then almost go off and then go at full speed again(all while the car is shut off).
Could this be a temp sensor? Or maybe the fan module? Is there a temporary solution to this so that the fans will stop? I looked under the hood and see the connectors leading to the fans but am unsure if its right or not.
By the way, its not running hot.
I just don't want them to keep running and drain the battery.
Any help would be GREATLY appreciated, and maybe in a timely manner being that they are still running haha.
Thanks, Bob
Thanks, Bob
