I have 2012 3.6L V6. Does anyone use coolant or anti freeze not bought at VW and if so what?
I actually just purchased it. Picked it up 3 states away because its what i wanted. However, when i started it first thing in morning, coolant light came on and it said check level. It just needs to be topped off.
It's a sealed system.A small amount of fluid loss over years / every 30,000 miles is nothing to be concerned about. We are heating water above the point of boiling. Water Vapor wants to escape. Small loss amounts can be topped off with distilled water.
Now, if you are actively losing coolant, then we have a problem. The point of normal loss (which should be really small imo) vs too much is subjective.
Curious about how low it is or to restate, how much it needed to be back at full again.I actually just purchased it. Picked it up 3 states away because its what i wanted. However, when i started it first thing in morning, coolant light came on and it said check level. It just needs to be topped off.
