1 - 10 of 10 Posts
Herc
Just wired up my 2004 with the "Deluxe" wiring kit from Treg Central. Soldered all connections and took power from the 2nd 12v outlet in the back. No problems with use, throwing fault codes, etc. Nice system if you don't want to go the factory route. Thanks to all who contributed to this process. Much simpler with all of the input.
For the DIY:
For those who don't wanna spend the extra money for a usually completely enclosed unrepairable module in case something shorts, here is a schematic which involves only 4 relays and some wires.
The jumper across the three relays will have all lights on if any relay is closed,no separation of signal circuits ,Marty
??????? Maybe you can elaborate on this
1 - 10 of 10 Posts
