Hello everyone! I wanted to ask about the battery. I need to change it. Can I totally disconnect the battery or do I need something to keep battery operations while the switch is made? Thank you. It a 2007 AWD 6 cilinders
Truth.NEVER, EVER use a battery charger on its own to power any vehicle for any reason.
The voltage out of them is filthy dirty and unregulated. You will likely destroy some electronics in the car.
You will most likely have to run the windows up and down (push/pull and HOLD the switch) so they relearn their full open and closed positions.Is there a "reset" routine that I need to do after the battery replacement?
