Transmission Manual R5 2005 - Club Touareg Forums
post #1 of 9 Old 04-11-2019 Thread Starter
Egon's Avatar
Touareg: 2004 R5 TDI
Lately I am experiencing a whirring noise when the clutch is released at the motion position, meaning when the car gets to move. This noise is getting harder but stops when the clutch is fully pressed and/or fully released.
Any advice?
Egon is offline
post #2 of 9 Old 04-11-2019
throw out bearing.
- Euro Paddle Shifter Steering wheel retrofit
- Autohold retrofit
- yrktreg tcm retune
- Malone stg 2 tune
- 3" turboback exhaust
- 265/65/18 duratracs on Cayenne wheels
04_sti is offline
post #3 of 9 Old 04-12-2019 Thread Starter
Egon's Avatar
Already everything is opened now, transmission and the while clutch kit, to together with the flywheel. That bearing was inside the manual transmission so it had to be dismantled. They say I need to change the whole clutch kit, and the flywheel too as all of the existing ones are pretty used so I need to replace the whole kit. Transmission is just fine but the clutch needs to be completely replaced. Does this sound reasonable?
Egon is offline
post #4 of 9 Old 04-12-2019
4ePikanini's Avatar
Touareg: 2005 R5 TDI
if you already dropped the transmission then do the whole clutch kit with release bearing, spigot bush, crank seal etc.
Do it all now while the transmission is out.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
post #5 of 9 Old 04-12-2019
As above, unless there is a very good reason not to, you should always fit a complete new clutch whilst the engine and gearbox are separated
post #6 of 9 Old 04-12-2019 Thread Starter
Egon's Avatar
Ok...doing the whole thing. It's 1000 Euro or 1200 USD and a new clutch kit will be installed. Transmission is dropped, oil will be changed, and the differential oil too. 2 litres each, meaning 4 litres altogether for the transmission and the differential. Clutch kit + flywheel is from LUK Germany. Hope everything will go fine!
Egon is offline
post #7 of 9 Old 04-15-2019 Thread Starter
Egon's Avatar
Ok, the whole thing is back into its place and the Touareg is on the roads again. Transmission is fine but clutch starts too early to put the car into movement. Anyways the problem now is with the first and reverse gear...sometimes it seems impossible to engage them. Even the second gear feels like it has two positions. What is this now?
Egon is offline
post #8 of 9 Old 4 Weeks Ago Thread Starter
Egon's Avatar
Gear one, reverse and sometimes the second gear have problems while being engaged. If I want to put the first gear after having pressed the clutch, it is very hard to get it to its position. While on the move all the gears are fine, the car reacts very well. I have these issues only in the city traffic or when I need to park...
Egon is offline
post #9 of 9 Old 4 Weeks Ago
Touareg: 2004 R5
If the clutch is engaging too near to the floor that probably means that when you try to change gears maybe you don't press the pedal down enough.
It disengages much lower than you're used to.
There would be an adjustment for that, somebody else will have to help you with that; I've never seen an R5 manual.
Flash635 is offline
Major Transmission Shifting Problem Nhr908 General Maintenance & Repair 61 10-22-2017 07:59 PM
For Sale: 2005 Touareg Manual tsanjose Classifieds 0 08-03-2013 04:21 PM
2005 owners manual LocoLobo Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 4 05-12-2012 03:00 PM
2005 VW Touareg Transmission Question suave6565 General Maintenance & Repair 22 11-10-2010 06:52 PM
