Trans shift - or lack of when cold - Club Touareg Forums
post #1 of 29 Old 11-06-2017 Thread Starter
Hi guys
Got a 2015 touareg r-line 3.0 v6 witht he 8 speed trans.
Now the weather has got colder, I seem to getting some gremlins sheltering from the cold in the transmission.
The car struggles to change from 3rd to 4th gear when cold and sometimes struggles from 2nd to 3rd too. It's odd because the dash display shows what gear the car should be in, but the revs are high and it certainly isn't in 5th or 6th gear.
I kind of know when this is likely to happen because about 10 seconds after setting off, I get a strange 'humming' noise from somewhere (guessing the trans). The hum lasts about 10 seconds and I never hear it again after that.
When the car is warm, the gear changes are fine.
Any ideas?
tk25 is offline
post #2 of 29 Old 11-06-2017
Try a gearbox reset.
Turn the ignition on but do NOT start the car.
Press the accelerator pedal firmly to the floor and hold it there for a full 10 seconds.
Release the pedal, turn the ignition off and remove the key.
If no improvement your 2015 car should still be under warranty, so take it back to the dealer and arrange for them to keep it for a couple of days having left it parked outside in the colder weather we now might be getting.
post #3 of 29 Old 11-06-2017
Mileage? If over 50,000 you might want to try changing the transmission oil.
If this was a T1/T2, I would test the external ATF thermostat that is in-line with the external ATF cooler, but these were removed in the T3... so that can not be the problem in a 2015.
If the problem continues after the fluid change, you will need to determine if the valve body is going bad.
If your 2015 is still under warranty, let VW deal with it.
post #4 of 29 Old 11-06-2017 Thread Starter
Thanks guys, I've booked it in with VW. It was worth asking to see if anyone else has had similar symptoms. I couldn't find any after a thorough search.
Hopefully this won't be one of those circumstances that 'isn't covered by warranty'.
tk25 is offline
post #5 of 29 Old 11-30-2017
Ranjr13's Avatar
Same issue on our '15
Any follow-up after you went to VW? Our '15 was slow to upshift when tranny cold from 3 to 4 ever since the car was new. Took it back in '15, but dealer said no problem, so lived with it. Now with new emissions fix, when tranny is cold it will not shift from 3-4 or 4-5 automatically. Making arrangements to take it back. Once warm it performs flawlessly.
Ranjr13 is offline
post #6 of 29 Old 12-04-2017 Thread Starter
Hi,
I took the car into VW and told them about the symptoms. They did all their usual checks (so i'm told) including transmission fluid levels etc, and all looked good. I also asked them to check for any software updates. It turns out there was one, which they subsequently applied. After driving it though, i honestly can't tell any difference. It's still slow to change gear when cold and revs in excess of 3000rpm. Once its warmed up, it's fine.
On a different note, I started the car this morning and was met with a barrage of warnings - the first of which disappeared quickly before I could fully read it, but Gearbox fault was the first one! The second was either traction control or stability management, and the third was an issue with the stop/start system. I turned off the engine, turned it back on again, and all was well this time. I've just been out and started it again - no warnings.
There is obviously something underlying here...
tk25 is offline
post #7 of 29 Old 12-04-2017
Originally Posted by tk25 View Post
On a different note, I started the car this morning and was met with a barrage of warnings - .
^^That is usually what happens when your battery voltage drops too low while the starter is turning over.
Yes, it is normal that if you let it run for as little as 30 seconds then restart, that the errors go away.
Either you had pulled a lot of juice out of your battery recently (without enough time for the engine to recharge it) or your battery is getting close to the end of it's useful life.
post #8 of 29 Old 12-04-2017 Thread Starter
@nickyt - That makes sense... I noticed when i got in the car this morning that one of the kids had left the interior lights on overnight. I guess that would explain that. I have a 60 mile commute to work so that probably gave it a good charge.
tk25 is offline
post #9 of 29 Old 12-04-2017
Yes. That would explain it. I have had similiar problems when I ran the battery down. After a good charge, everything is good again.
post #10 of 29 Old 12-05-2017
Ranjr13's Avatar
TK25 - thanks for reply. I can't bring myself to letting a cold engine rev to 3,000 to shift, so I manually help it and like yours, when it's warm, it's flawless. It's going in for a 90K service in a month or so, will see if they can do anything at that point. I have received the same messages since I've had the car. I've never run the battery down, but I suppose voltage is an explanation, not sure why - I drive the car every day, nothing can be left on with computer shutting off lights after a few minutes. Best of luck with yours - love ours, just wish the tranny would act as good cold as it does warm. Happy holidays.
Ranjr13 is offline
