Loosing oil after oil change. - Club Touareg Forums
post #1 of 19 Old 08-19-2018 Thread Starter
I have a 2011 VR6 with 145K miles. After changing my oil, i get a low oil indicator alarm soon after driving 1500-2000 miles. The indicator asks to add 1-1.5 quartz oil. This happened twice where I top-off or add oil once or twice between oil changes.
The dealer told me that the engine burns more oil as it ages and will need to change oil more frequently, every 5K instead of 10K
Anyone experience the same issue and if so any solutions to consider ?
Munz is offline
post #2 of 19 Old 08-20-2018
oldhifi's Avatar
I don't believe what the dealer says, should not be burning oil. Are you sure you filled it up correctly?
oldhifi is offline
post #3 of 19 Old 08-20-2018
What type of oil are using? weight , synthetic ? You shouldn't burn that much between changes.
tadpole is offline
post #4 of 19 Old 08-20-2018
New2Tregs's Avatar
I too own an '11 Treg gasser with ~76.5k on the clock, and have experienced the wonderful oil loss of these vehicles. I'm using Ravenol VMO 5W-40 which was changed ~1,500 miles ago along with a new OEM filter and new drain plug.
I've had to add oil 3 times so far when I noticed the "electronic dipstick" show the oil level was down to ticks from max. Granted it's not much each time, I think ~4oz. brings it back to max each time. So 12 oz. in 1,500 miles is not as much as you but still more than I think ANY vehicle should use. I posted in the thread below but have not yet received a response.
https://www.clubtouareg.com/forums/f...ml#post2009563
New2Tregs is offline
post #5 of 19 Old 08-20-2018
Touareg: 2007 V10 TDI
I would think if it was using 1.5 Q in 1500 miles it would have visible smoke from the exhaust and you would be able to smell it from the exhaust pipe. I would get a flashlight and get under it when its hot (or even cold) and look for anything wet around looking like oil. Have you seen any oil spots in your driveway?
middleton61 is offline
post #6 of 19 Old 08-20-2018
I would say the oil burn mentioned above is not normal, we have 11 VR6 with 110K and I change oil using Ravenol VMO 5w40, next oil change counter is under 2K and have not added any oil.
Electronic level still has 3 bars left.
For some reason VW engineers think some oil burn is ok but more than 1.5 quarts in 10K is excessive IMO
VWBob is offline
post #7 of 19 Old 08-20-2018
Interesting post. Using this to get to 15 messages.
mfolkmann is offline
post #8 of 19 Old 08-24-2018 Thread Starter
5W40, synthetic. I agree I shouldn't be burning that much oil.Looking for help to understand the issue since the dealership's failed to tell me something that makes sense
Munz is offline
post #9 of 19 Old 08-24-2018 Thread Starter
Good thought, I checked and there was no oil residue found in the tail pipes and no smoke when running. The one thing I noticed is the smell of gasoline, out of exhaust, upon startup is now stronger than before.
Munz is offline
post #10 of 19 Old 08-24-2018
New2Tregs's Avatar
IMO the oil blow by occurs when you accelerate and the RPM's climb above 2.5K. Therefore you won't be able to see the smoke from the exhaust. The blow by might even be small enough on each acceleration that people behind you might not see it either.
In my case there is no oil residue/streaks of any kind all around the engine. It's bone dry. That leads me to believe that it coming out the exhaust... at least in my case.
