Front Differential Failures common? - Club Touareg Forums
View Poll Results: Has your Front or Rear Differential Failed or makes noise?
I hear the grinding sound in my front differential 22 81.48%
I have replaced my front differential already 5 18.52%
I have a failure or pending failure in my rear differential 5 18.52%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
post #1 of 30 Old 11-29-2012 Thread Starter
Touareg: 2004 R5 TDI
Can everyone who has had the front differential fail (grinding, metal on metal sound associated with acceleration or deceleration) please comment? I think its time that Volkswagen come to terms with this defective part. It is notable that we are not seeing the same rate of failures on the rear differential even though mileage and wear is the same. How do they explain that?
Please sound off, maybe we can get a policy change established. My dealer says that if you push VWA they will own up to the problem and help to resolve the issue. We need more factual evidence that there is a consistent problem so please sound-off here if you've had this problem 2004-2010.
Taureg is offline
post #2 of 30 Old 12-04-2012
diff bearings
Hi , just changed the main bearings in the front diff of my 2004 3.2 with 86000 miles and full vw service history , vag did not want to know even with low miles and full history at the same dealer !!! the diff oil level in these units is to low
the bearings sit dry when parked they are splash lubed when running ..
njm123 is offline
post #3 of 30 Old 12-04-2012
What were the symptoms?
How much did it cost?
Who did it for you?
post #4 of 30 Old 12-04-2012
diff bearings
Hi , repaired it myself i work on heavy plant , diff repairs are a common job , the bearings can be sourced for about 45.00 i used timken as fitted by zf when new , the bearings are used in bmw diffs as well , they are imperial bearings in the diff beware skf can supply a bearing with the same part numbers but they are metric part numbers in diff are KLM503310 seat KLM503349 bearing you will struggle to x ref the KLM number but K stands for imperial measured bearing , timken make an imperial LM 503310 LM 503349 which is the same part , bearings in the diff had slight wear but this caused side play in the diff , fitted new bearings original shims were spot on , i have added 1/4 liter extra oil to try and help the bearings survive , there is still a tiny noise from the diff which will be slight wear in the crown wheel and pinion due to free play in diff when it was run with the worn bearings , damage to the original bearings was lack of lube . diff was loud lifting of the throttle and just on the throttle , hard right hand bends made it growl
njm123 is offline
post #5 of 30 Old 12-04-2012
Jimbuffalo's Avatar
I had mine replaced at 108,000 miles....about 4,000 miles past the expiration of my extended warranty. Symptoms were constant whining that worsened over time. I put up with it for about 4 months. Cost was about 2900 + some labor to replace.
I do have the old front differential laying about if someone needs it to effect repairs on theirs....ie. rebuild mine, and then install it. PM if interested...
2005 V8.
White over Anthracite 2016 TDI Executive
Jimbuffalo is offline
post #6 of 30 Old 12-04-2012
Touareg: 2007 V6
How often were the differential oils changed? Good to know there is an option to repair the otherwise expensive unit by using bearings alone.
It is bad enough to have to wonder about the valve chest going and the driveshaft bearing too. And then this revised 40K fluid change letter.
SamT is offline
post #7 of 30 Old 12-06-2012
I have mentioned this before, but once again for some odd reason, other than Jimbuffalo, it is the 04 3.2 V6 owners reporting all the front diff failures on here.
170000km still on same front diff here, no symptoms yet. Replaced fluid a while back ago. I noticed the fluid darker than I would have liked, and therefore made the right move to replace that beat up fluid. The mechanic agreed as well.
Sent from my iPhone using AutoGuide.com Free App
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
volkswagendude is offline
post #8 of 30 Old 12-06-2012
Can you elaborate? I don't know that I have seen this letter.
2005 V8, Venetian Green, no mods
Green Egg is offline
post #9 of 30 Old 12-06-2012
Touareg: 2007 V6
Okay, a bit of mixup here. The 40K change interval is in the 09-11 owner's manual (V6 TDI). The letter is sent to disregard the 40K interval. Then there is a letter for all VW models equipped with the 09G Aisin-Werner 6-speed (TF-60N) to change at 40K miles instead of leaving it for the lifetime.
Slow Burn's post #16:
https://www.clubtouareg.com/forums/f4...e-12381-2.html
Kman1984's post #7:
https://www.clubtouareg.com/forums/f4...ice-61521.html
Clutchless's post #43:
MCSA Tranny Fluid Change - Page 2 - North American Motoring
SamT is offline
post #10 of 30 Old 12-07-2012
BANNED
I shipped one for a client that had an 05 V8
nltomba is offline
front differential
