DIY TRANSMISSION FLUID CHANGE pics :) ATF - Club Touareg Forums
 6Likes
post #1 of 358 Old 01-05-2013 Thread Starter
nikoloz's Avatar
hi al touareg lovers today i changed ATF so i took step by step pics as promised and here they are
fists of all if you have air ride lock it and raise you monster
Name:	20121207_007-2 [1600x1200].jpg
ID:	19663   Click image for larger version
Name:	111 [1600x1200].jpg
Name:	222 [1600x1200].jpg
ID:	19665   Click image for larger version
Name:	333 [1600x1200].jpg
Name:	444 [1600x1200].jpg
ID:	19667   Click image for larger version
Name:	555 [1600x1200].jpg
Name:	666 [1600x1200].jpg
ID:	19669   Click image for larger version
Name:	777 [1600x1200].jpg
Name:	7777 [1600x1200].jpg
ID:	19671   Click image for larger version
Name:	77777 [1600x1200].jpg
Name:	777777 [1600x1200].jpg
ID:	19673   Click image for larger version
Name:	7777777 [1600x1200].jpg
Name:	7777777. [1600x1200].jpg
ID:	19675   Click image for larger version
Name:	7777777.. [1600x1200].jpg
Name:	888 [1600x1200].jpg
ID:	19677   Click image for larger version
Name:	999 [1600x1200].jpg
Name:	1000 [1600x1200].jpg
ID:	19679   Click image for larger version
Name:	20130105_051-2 [1600x1200].jpg
Name:	20130105_054-2 [1600x1200].jpg
ID:	19681   Click image for larger version
Name:	20130105_007-2 [1600x1200].jpg
nikoloz is offline
The Following 2 Users Say Thank You to nikoloz For This Useful Post:
trdltly (05-07-2019), V10DeezulDub (10-12-2015)
post #2 of 358 Old 01-05-2013
I'm not quite sure I understand pumping the new ATF fluid in.
It looks as though you are pumping it in through the same drain drain hole the old ATF came out of at the start.
It you are, why isn't the ATF coming out as soon as you start putting it in?
Excellent post by the way.
kenrevo (05-30-2017)
post #3 of 358 Old 01-05-2013 Thread Starter
nikoloz's Avatar
no its not the drain hole its the one which must be used for filling the new oil #1 is for draining and #2 is for filling, most of the time both of them must be taken off at the same time to be cleaned well
nikoloz is offline
post #4 of 358 Old 01-05-2013
Thank you.
post #5 of 358 Old 01-05-2013
awesome write up!!!!! will be doing this procedure soon..What is the part number of the atf and how many quarts did you end up using since typically that is how it is sold in quart bottles..
92 Honda Prelude Si, 96 Acura GSR, 98 Integra Turbo LS, 04 Volkswagon Touareg V8, 02 Acura TL, 06 Touareg, 04 murano, 00 crv se, 97 Integra gsr.
johnsc2 is offline
post #6 of 358 Old 01-06-2013 Thread Starter
nikoloz's Avatar
the part i used are OEM and the numbers are:
transmission filter 09D 325 435
pan gasket 09D 321 371
ATF G 055 025 A2 i bought 7 bottles of ATF
nikoloz is offline
The Following User Says Thank You to nikoloz For This Useful Post:
ElVersace (11-02-2015)
post #7 of 358 Old 01-06-2013
Hylander's Avatar
Touareg: 2007 V6
3 questions:
1. After you filled 3 liters and started the engine, did you leave the engine on while pumping the remaining 3.7 liters?
2. Additionally, did you have to apply any gasket compound after removal of old gasket and before the new gasket was replaced?
3. How can you be certain all of the old fluid drained? One post I read stated that there were inaccessible chambers in the the tranny that required the fluid to be vacuumed out.
Thanks for the write up ... it looks easier than everyone had previously thought, which concerns me ... is it really that easy?
2008 Jetta SE White
DREAM! 2012 Touareg TDI White
Hylander is offline
post #8 of 358 Old 01-06-2013 Thread Starter
nikoloz's Avatar
question 1 - yes engine must be running
question 2 - i have not used anything, only new gasket
question 3 - total amount of the transmission oil is 10 liters in the transmission but only 7 liters are replaceable if you do it in the way as i did, using vacuum i have not heard to be honest. 3 liters of old oil stays in the radiator and cooling system of transmission hope i answered your questions
nikoloz is offline
post #9 of 358 Old 01-06-2013
ATF Level, Checking and Filling
  • The ATF level is specified by a permanently installed overflow tube in the oil pan.
  • The ATF level is checked when fluid is a specific temperature and with engine running. The ATF temperature is read out by the Vehicle Diagnosis, Testing and Information System VAS 5051B . If the test temperature has been reached, the sealing plug in the oil pan is removed to check the ATF. Marty
Test temp is 30 C
Depiry is offline
post #10 of 358 Old 01-06-2013 Thread Starter
nikoloz's Avatar
do you suggest to check it again?? attachment does not work....
nikoloz is offline
