Camshaft position sender - Club Touareg Forums
post #1 of 105 Old 03-10-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
My '03 Touareg is the 7LA model
With a VR6 3.2L petrol AZZ engine
If i take out the inlet camshaft position hall sender G40
And make shure that it remains connected to
earth (T121a/ 108 at J220 Motronic control unit),
power supply (T121a/ 98 at J220 Motronic control unit) and
signal (T121a/ 86 at J220 Motronic control unit) wires
Arranging that i can probe the wires with a multimeter
With the ignition on, in normal conditions and with a fully loaded battery, does anyone know the voltage i should read
Between earth and power supply
Between earth and signal wire in rest
Between earth and signal wire while metal in front of the hall sender
Please rescue me
PatTouareg is offline
post #2 of 105 Old 03-10-2019
I have the same engine.
What are your symptoms?
here is a vid of how to check the sensors:
TRespect is offline
post #3 of 105 Old 03-10-2019
TRespect is offline
post #4 of 105 Old 03-10-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Hi TRespect,
Is this test VR6 specific?
Because different engines = different voltages and difference in pull or drop
I'll have to wach the vid some more times
Also i have not many electronical devices, thats why i would like to start measuring using the ECU at first
This is how i have set it up, hoping i could start easy
Problem started out as longer cranking and has evolved to a no start
I can smell that engine gets petrol and from time to time he gives a little puf as if he wants to start
G40, G163 and G28 i replaced
All codes i get have to do with camshaft position sensors
post #5 of 105 Old 03-10-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
post #6 of 105 Old 03-10-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Sorry, trying to to get to know how to use the forum
post #7 of 105 Old 03-10-2019
Might be fuel pump issue also. Try this:
TRespect is offline
post #8 of 105 Old 03-10-2019
Originally Posted by PatTouareg View Post
Hi TRespect,
Apparently these sensors are all alike. But not sure.
If the sensors are new so you're good there?
You need to post a vcds autoscan.
TRespect is offline
post #9 of 105 Old 03-14-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
I will make and post a new scan asap!
Wouldn't there be detailed info to be found about what voltages the ECU sends to the switches and what change in voltage the signal wire makes when the switch switches?
Would be so simple and fast to check ...
post #10 of 105 Old 03-14-2019
I think you can see the voltage in a vcds log but I don't know what the exact measuring blocks are for the VR6.
Check here and log all the block:
https://www.ross-tech.com/vag-com/m_blocks/090-098.html
TRespect is offline
Camshaft Position Sensor 2 Location V6 archie666 Engine, Transmission and Exhaust 3 3 Weeks Ago 01:25 AM
which is g163? 2 camshaft position sensors? b6commuter Engine, Transmission and Exhaust 5 02-02-2017 08:04 PM
VW TOUAREG V6 3.0 176 KW 2008 Camshaft Position Sensor (G40) fault Exclusive Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 5 01-22-2017 08:14 AM
p1347 code.17755 - Camshaft Position Sensor 2 archie666 Engine, Transmission and Exhaust 10 04-16-2016 02:38 AM
CAMSHAFT POSITION SLIPING? JPARSONS General Maintenance & Repair 2 10-25-2006 06:42 AM
