Camshaft position sender - Page 7 - Club Touareg Forums
post #61 of 102 Old 03-22-2019
That gave the radio unit enough time to eat up the poor Treg
TRespect is offline
post #62 of 102 Old 03-22-2019
Aftermarket radios have caused a lot of problems for VW. If VW would just release a universal adapter or the pinouts to make one, it would solve a lot of issues. I have seen it stated on the forums that at least one of the major sources has incorrect wiring information. If you follow those directions you will disable at least one of the canbus wires. The canbus is the ethernet of the car, every car module is hooked into it and uses it to talk to the other modules.
There are two canbus wires in all Touaregs. They can referred to as can high and can low. When both are working, the system can communicate in high speed mode. If one is lost, the system then works in a low speed mode.
The situation is so bad that most VW dealers will not work on a vehicle with a aftermarket radio. You have to pull and unplug the radio before going to the dealer. If the radio is connected to the vehicle, no dealer service.
google.com/search?q=vw+aftermarket+radio+issues
There is nothing wrong with aftermarket radios in the Touareg, but getting them properly wired is much more tricky then in other vehicles.
nickyt is online now
post #63 of 102 Old 03-22-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Radio is out and wiring is cut back to standard
Not starting yet, so i am searching for the damage that has been done
Motronic fuse is ok, hoping to be able to chech 2 Motronic relays tomorrow
I also found problems in the LPG wiring, so for now i also disconnected LPG ECU!
Hoping for dry weather next days
PatTouareg is offline
post #64 of 102 Old 03-26-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
All over the car i find wires that are extended in a sloppy way, don't understand why (
Cleaned up LPG wiring and solved one problem: i now have a accurate reading of LPG tank filling )
Cleaned up radio wiring
I check things, a little every day ... rodents don't seem responable, didn't find any proof of them being there
Checked fuses and relays feeding engine ECU, no problems there
Still a lot to check ...
post #65 of 102 Old 03-26-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
The engine ECU is a Bosch Motronic ME 7.1.1
Does anyone know the pin layout for this, please?
post #66 of 102 Old 03-27-2019
http://www.transpondery.com/pinout_g...e7-pinout.html
TRespect is offline
post #67 of 102 Old 03-27-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Originally Posted by TRespect View Post
I can only see 7 pins, correct?
post #68 of 102 Old 03-27-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
I think there are 121 ...
post #69 of 102 Old 03-27-2019
81 i guess but not all are used.
TRespect is offline
post #70 of 102 Old 03-27-2019
Here is the connector. I bought one to clone my ecu.
http://s.aliexpress.com/b2QbiqMF
TRespect is offline
which is g163? 2 camshaft position sensors? b6commuter Engine, Transmission and Exhaust 5 02-02-2017 08:04 PM
VW TOUAREG V6 3.0 176 KW 2008 Camshaft Position Sensor (G40) fault Exclusive Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 5 01-22-2017 08:14 AM
p1347 code.17755 - Camshaft Position Sensor 2 archie666 Engine, Transmission and Exhaust 10 04-16-2016 02:38 AM
Camshaft Position Sensor 2 Location V6 archie666 Engine, Transmission and Exhaust 2 03-08-2015 07:11 PM
CAMSHAFT POSITION SLIPING? JPARSONS General Maintenance & Repair 2 10-25-2006 06:42 AM
