Camshaft position sender - Page 6 - Club Touareg Forums
post #51 of 102 Old 03-19-2019
You case looks like this one too:
https://www.clubtouareg.com/forums/f...ee-273881.html
TRespect is offline
post #52 of 102 Old 03-20-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Weather is getting better here, next days i will get kuddly with the car, check everything you suggest and will report for shure
Thx.!!!!!!!!
PatTouareg is offline
post #53 of 102 Old 03-20-2019
Just yank that radio out, check the harness and wires and start the treg without the radio installed. I bet the install of that radio messed up something. Then go over all the fuses using the ssp pdf above.
TRespect is offline
post #54 of 102 Old 03-20-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Radio out (started working again the moment i pulled it out LOL),
Car not starting, but it randomly wants to from time to time, so i suspect fuel delivery and sparks are there, timing is wrong
(normal with speed engine and camshaft position errors)
I will be doing a lot of checking in the next days
Never seen such a bunch of cut, re-connected and cross-connected wires, why do people do this????????
post #55 of 102 Old 03-20-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
TRespect: any idea about cranking RPM?
Another question i have: i put in a new battery: should i code it in this car according to you?
post #56 of 102 Old 03-20-2019
I think the root cause is there. That mess did blow a fuse or burn something which is causing all the communication errors and preventing the car from starting. Now you need to check all the fuses are good. This should be your next step. But first you need to remove all the splicing and clean that harness mess. There probably some wires creating shorts there. Just cut it back to oem wiring and tape the wires until you fix the starting issue.
TRespect is offline
post #57 of 102 Old 03-20-2019
I haven't checked but it normally goes to 1100rpm when cold and then comes back to around 870 after a minute.
You don't need any battery re-setting. Just plug and play.
TRespect is offline
post #58 of 102 Old 03-20-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
We think alike LOL
I'll clean up this mess first and than i will go over fuses, wiring, ... and than i will report
post #59 of 102 Old 03-20-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
I'm referring to the moment the engine is cranking, but isn't starting yet: what RPM does the starting motor make the engine do?
Great
post #60 of 102 Old 03-21-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
I got back in contact with the seller today: he has driven the car a couple of months, for 2 to 3000km after having changed the radio ...
which is g163? 2 camshaft position sensors? b6commuter Engine, Transmission and Exhaust 5 02-02-2017 08:04 PM
VW TOUAREG V6 3.0 176 KW 2008 Camshaft Position Sensor (G40) fault Exclusive Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 5 01-22-2017 08:14 AM
p1347 code.17755 - Camshaft Position Sensor 2 archie666 Engine, Transmission and Exhaust 10 04-16-2016 02:38 AM
Camshaft Position Sensor 2 Location V6 archie666 Engine, Transmission and Exhaust 2 03-08-2015 07:11 PM
CAMSHAFT POSITION SLIPING? JPARSONS General Maintenance & Repair 2 10-25-2006 06:42 AM
