Camshaft position sender - Page 5 - Club Touareg Forums
post #41 of 102 Old 03-18-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
That's why i have a cat sleeping on the engine loooooooooool
No, i will keep it in mind, but as i said earlier: until now, didn't see rodents over here nor did i hear of problems with them by others
On the other hand ... problems began very short after buying the car, at the sellers it was sitting outside and over there it was a more rural environment
PatTouareg is offline
post #42 of 102 Old 03-18-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Originally Posted by TRespect View Post
What I see is all modules are offline and not communicating. You need to check power is getting to the easiest or most accessible module. Or just start with the fuse box. Do you happen to live in an area where a rodent can get to the wires and chew them. I've seen posts like these
What in the scan report exactly indicates offline and not communicating, please?
Like i said, completely new in VCDS ...
Am i correct that modules that are offline cannot display DTC's or is it more complicated than that?
post #43 of 102 Old 03-18-2019
You can see that in the 'No Signal/Communication - Intermittent'.
TRespect is offline
The Following User Says Thank You to TRespect For This Useful Post:
PatTouareg (03-19-2019)
post #44 of 102 Old 03-18-2019
Start by this:
Check fuses and wiring.
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2701
Coding: 0100452
Shop #: WSC 31414 000 00000
VCID: 448D52C90480FE9
4 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
006 - Short to Plus - Intermittent
01498 - Bulb for Parking Lamps; Right (M3)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
000 - - - Intermittent
TRespect is offline
post #45 of 102 Old 03-18-2019
Look down behind your engine where the wiring harness feeds up across the top of the transmission, perhaps using a mirror or scope. There is a great little nesting spot on top of the tranny. My V10 cam sensor is still running with wiring patched into the large ECM harness.
lgibson is offline
post #46 of 102 Old 03-18-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Ok, i will report as soon as i checked what you guys suggest!
For info: my second car does not show any wiring problems
Meanwhile i would be happy if it turns out to really be a wiring problem, since i was afraid that it would be timing chain problem, considering the camshaft error codes
post #47 of 102 Old 03-18-2019
What happens when you turn the key to ignition? Does your dash show any errors? Do the lights work? The radio? The brake lights?
TRespect is offline
post #48 of 102 Old 03-19-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
TRespect: could you check what RPM your car shows at the moment of cranking, please?
post #49 of 102 Old 03-19-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Ok, this is my dash: ignition on, not cranking nor engine running ...
I'm ready for Christmas lol
2nd picture comes seconds after first
All bulbs/lights seem to work, central locking also, heating also, electric seats also
Only components that don't seem to work are, as i mentioned earlier, the radio and the A/C (perhaps just low on refrigerant)
The seller has put this radio in, prior to selling it, he says because the original wasn't working.
I don't know what brand or model it is, but it is not original!
And ... first days i had the car: it worked, than it died
The clock in the dash runs as long as the ignition is on and resets to 0:00 when ignition is off
ID:	221863   Click image for larger version
post #50 of 102 Old 03-19-2019
Start by removing that radio then. Maybe it fried some somthing or it blew some fuses.
TRespect is offline
which is g163? 2 camshaft position sensors? b6commuter Engine, Transmission and Exhaust 5 02-02-2017 08:04 PM
VW TOUAREG V6 3.0 176 KW 2008 Camshaft Position Sensor (G40) fault Exclusive Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 5 01-22-2017 08:14 AM
p1347 code.17755 - Camshaft Position Sensor 2 archie666 Engine, Transmission and Exhaust 10 04-16-2016 02:38 AM
Camshaft Position Sensor 2 Location V6 archie666 Engine, Transmission and Exhaust 2 03-08-2015 07:11 PM
CAMSHAFT POSITION SLIPING? JPARSONS General Maintenance & Repair 2 10-25-2006 06:42 AM
