Camshaft position sender - Page 3 - Club Touareg Forums
post #21 of 102 Old 03-15-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Originally Posted by TRespect View Post
I don't know about the camshaft sensor but the knock sensor for example has a specific torque. Check this kind of detail.
Smart thinking, but no problem there, i can assure you
PatTouareg is offline
post #22 of 102 Old 03-15-2019
Good to know
TRespect is offline
post #23 of 102 Old 03-15-2019
Just remember that the treg does not like a bad battery. Make sure you're good on this one.
TRespect is offline
post #24 of 102 Old 03-15-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Too many errors related to voltage. What about the battery?
You need charge the battery, erase the code the crank and scan.
You know ... deep down i was feeling the same
And: the car has been on a charger for some time already and, when i removed the charger, sometimes i got the idea that the battery didn't keep voltage good enough ...
So: i will replace the battery, make shure that it is fully charged, erase the codes, crank the engine, do a scan and than post the result
Please hold on
post #25 of 102 Old 03-15-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Are you single? I am loooooooooool
post #26 of 102 Old 03-15-2019
TRespect is offline
post #27 of 102 Old 03-15-2019
You should thank Tapatalk
TRespect is offline
post #28 of 102 Old 03-15-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
Thank you very much Tapatalk hahahaha
post #29 of 102 Old 03-15-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
I'll be back!!!!!!!!!!
post #30 of 102 Old 03-16-2019 Thread Starter
PatTouareg's Avatar
Touareg: 2003 V6
So ... brand-new 110Ah / 920A car battery: check
Cleared DTC's
Did some cranking ... no-start
Made new auto scan: think i have to examine Engine Speed sensor G28 (which is brand-new) further, but than again: what is de most efficiŽnt way to do that ... old sensor as well as new sensor gives problems, so there is something wrong with wires, sender wheel of ECU: correct?
Somewhere i have read that no G28 signal = no-start ...
Saturday,16,March,2019,16:15:23:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 7L - VW Touareg
VIN: WVGZZZ7LZ3D006640 Mileage: 173210km/107627miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BE HW:
Component: MOTRONIC ME7.1.1G 0008
Coding: 0000133
Shop #: WSC 02402 202 05928
VCID: 4FA76DE5DDC60D1
4 Faults Found:
16706 - Engine Speed Sensor (G2
P0322 - 004 - No Signal - Intermittent
16725 - Camshaft Position Sensor (G40)
P0341 - 004 - Implausible Signal
16955 - Brake Switch (F)
P0571 - 008 - Implausible Signal
16730 - Camshaft Position Sensor (G163)
P0346 - 004 - Implausible Signal
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 A
Component: AL 600 6Q 0360
Coding: 0004136
VCID: 2C5D1A698C10169
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent - MIL ON
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 A
Component: ESP ALLRAD MK25 0105
Coding: 0014337
Shop #: WSC 31414 000 00000
VCID: 377735054556A51
2 Faults Found:
00778 - Steering Angle Sensor (G85)
000 - -
Part No SW: 3D0 909 131 T HW: 5WK 470 21
Component: Kessy 6120
Coding: 0000232
VCID: 32610411AE34409
Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 D
Component: CLIMAtronic R/L 0302
Coding: 0001020
VCID: 31630B1DAB327B1
4 Faults Found:
002 - Lower Limit Exceeded - Intermittent
014 - Defective
01336 - Data Bus for Comfort System
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2701
Coding: 0100452
VCID: 448D52C90480FE9
4 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
006 - Short to Plus - Intermittent
01498 - Bulb for Parking Lamps; Right (M3)
000 - - - Intermittent
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 B
Component: 4 Airbag 8.4E+ H07 0641
Coding: 0008244
Shop #: WSC 00000 000 00000
VCID: 2241F451FED4D09
4 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
001 - Upper Limit Exceeded - MIL ON
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
002 - Lower Limit Exceeded - MIL ON
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
011 - Open Circuit - MIL ON
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
014 - Defective - Intermittent
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 B
Component: Lenksšulenmodul 3201
Coding: 0000011
VCID: 3E7920216A6C949
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 880
Component: KOMBIINSTRUMENT RB4 2601
Coding: 0007111
VCID: F4ED420994A08E9
1 Fault Found:
00464 - Control Module with Display for Radio and Navigation (J503)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0E54E19E0B8B29
1 Fault Found:
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F071D252DE65D1
No fault code found.
Part No: 7L0 959 933 C
Component: 4L HSG 3214
Coding: 0000065
Shop #: WSC 03816 202 82061
VCID: 3C7D2A297C70869
Part No: 7L0 959 701
Component: Tuersteuergeraet FS 0101
Part No: 7L0 959 702
Component: Tuersteuergeraet BF 0101
Part No: 7L0 959 703
Component: Tuersteuergeraet HL 0101
Part No: 7L0 959 704 B
Part No: 7L0 907 719
Component: Neigungssensor 0018
Part No: 7L6 951 171
Component: A Innenraumsensor 0019
11 Faults Found:
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
01516 - Terminal 30; Left
00926 - Terminal 30
00323 - Vehicle Inclination Sensor (G384)
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J38
01334 - Door Control Module; Rear Right (J389)
Address 68: Wiper Electr. Labels: None
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000255
Shop #: WSC 131071 1023 2097151
End ---------------------------------------------------------------------
which is g163? 2 camshaft position sensors? b6commuter Engine, Transmission and Exhaust 5 02-02-2017 08:04 PM
VW TOUAREG V6 3.0 176 KW 2008 Camshaft Position Sensor (G40) fault Exclusive Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 5 01-22-2017 08:14 AM
p1347 code.17755 - Camshaft Position Sensor 2 archie666 Engine, Transmission and Exhaust 10 04-16-2016 02:38 AM
Camshaft Position Sensor 2 Location V6 archie666 Engine, Transmission and Exhaust 2 03-08-2015 07:11 PM
CAMSHAFT POSITION SLIPING? JPARSONS General Maintenance & Repair 2 10-25-2006 06:42 AM
