3.2 Valve cover gasket replacement - Page 3 - Club Touareg Forums
post #21 of 47 Old 09-02-2018 Thread Starter
Here is a video of the issue I'm trying to solve:
Touareg mk1 vr6 3.2 intake manifold issue
TRespect is offline
post #22 of 47 Old 09-02-2018 Thread Starter
TRespect is offline
post #23 of 47 Old 09-03-2018 Thread Starter
No VR6 drivers?
TRespect is offline
post #24 of 47 Old 09-03-2018 Thread Starter
TRespect is offline
post #25 of 47 Old 09-06-2018 Thread Starter
Still looking for vr6 owners
TRespect is offline
post #26 of 47 Old 09-06-2018
gazaflash's Avatar
I have a VR6 3.6ltr. Intake manifold slightly different to yours.
other comments:
The valve cover gasket is made of good rubber material. Would it not be best to replace the gasket and not use silicon sealant? This is not your cheap and nasty cork / paper gasket that some manufactures use.
Oil residue in the head shows me that the oils has not been replaced regularly.
You do not have any VAGCOM errors? Surprising!
Is the EGR system check test pressurising the manifold. There is a thread on this website whereby an owner blew the intake manifold apart. Be careful.
Bon chance with your repair
gazaflash is offline
post #27 of 47 Old 09-06-2018 Thread Starter
Yes valve cover was sludgy ! I cleaned as much as I could.
No vcds errors. I suspect the variable intake change-over system as it seems to be locked in one position and does not change with rpm. I will check the hoses and the valves.
TRespect is offline
post #28 of 47 Old 09-06-2018 Thread Starter
Treg is resting since the cluster smoked i won't be driving it before fixing the cluster and this issue.
TRespect is offline
post #29 of 47 Old 09-06-2018
gazaflash's Avatar
Sounds like you have your work cut out for you!
“cluster smoked”!? What do you mean?
Do you have a Mityvac hand vacuum pump to check the diaphragm and operation of the linkage. This is a known fault on older Touareg’s. Look up threads on intake manifold linkage broken. The plastic linkage rattles its whole life and wears through.
post #30 of 47 Old 09-06-2018 Thread Starter
I started a threa about the dead cluster. I was driving and smike came out above the cluster. Cluster needles and digital screen went dead except gas and oil temp.
The linkage is good. It just does not move when I rev the engine. I guess the hoses are worn out especially the one caming from the manifold and going into the valve which drives the linkage. I will need to find a replacement hose since vw sell the whole system only at around 200€. I did repaire the hose but I think the whole system with the valve and the solenoid is not working correctly due to tear and wear. The tiny hose was crumbling when I trued to repair it.
TRespect is offline
