2017 Sport w/Tech Engine Ingested Water - Page 7 - Club Touareg Forums
post #61 of 231 Old 07-13-2018
bobbydigitali's Avatar
Are people experiencing this issue in both Gas and Diesel engines ?
bobbydigitali is offline
post #62 of 231 Old 07-24-2018
Hi -
I am currently going through the same situation, except my car was in my driveway over night in a really bad rain storm. I got in the car the morning after the storm, heard a weird noise, pulled out of driveway and didn't go far when the car starting bucking, smoking, lost power and car died. Had to have car towed to service at dealership.
Spoke to service manager this morning and he accused me of driving through water and will have to pay for any damages. I said "Hell NO".
Will keep you posted!
jodicphoto is offline
post #63 of 231 Old 07-24-2018
Originally Posted by jodicphoto View Post
Hi -
Another member who lost power while on the road, making this into a serious safety defect, according to the rules posted on the NHTSA recall website.
Be sure to file your problem. It is the only way the VW of NA will admit to the problem. Strange that there is a safety recall in China for this same problem, isn't it?
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
nickyt is online now
post #64 of 231 Old 07-24-2018
Thanks for your note. I submitted a complaint to nhtsa this morning. And I do believe there is a safety recall in China for this very thing. This is the second time this has happened to me. The first was in October and service said there was absolutely nothing wrong with my car and sent me on my way. We had written a note to be put in our file about how unhappy we were with service. My husband will now deal with the dealership after finding out this has been a problem with the car and hey are acting like its a new situation.
post #65 of 231 Old 07-25-2018
I recently bought a 2016 tdi treg. Living in a heavily rained area I'm now worried about this issue. For prevention, have anyone installed the 'water guard' from China's recall? Parts number seems to be 7P6 805 962 C
geltik is offline
post #66 of 231 Old 07-27-2018
Exclamation I have the same issue!
I would like to start out and thank everyone who posts on this forum! I would not have even thought to look at something like this. I'm new to the Touareg scene, but not new to VW diesels. I purchased my 2016 VW TDI LUX late last year. It sat on the dealer's lot for approx. 2 years waiting for the fix. It now has 3600 miles on the odometer, and I have the same problem with water entering into the air box.
SharBlast is offline
post #67 of 231 Old 07-27-2018
Here are some images. While the filter is definitely wet, it didn't start to break down yet. Might have dodged a bullet thanks to you guys!
ID:	216969   Click image for larger version
ID:	216973   Click image for larger version
post #68 of 231 Old 07-28-2018
clickscrazy's Avatar
After seeing this, I decided to check mine. I had just drove about 70 miles in the rain the day before checking, and it rained in the evening.
The next day I opened mine up, and my filter was dry. I have a brand new filter by the way.
HOWEVER, There was a tiny puddle the size of a nickel in the corner at the bottom of the air box.
I cleaned out a small amount of debri in the box, and poured some water in the drain to ensure it worked (it did).
So, it seems water does get in somehow, but in my case, it didn't seem to bad.
clickscrazy is offline
post #69 of 231 Old 07-28-2018
Here is a photo
Here is a photo
post #70 of 231 Old 07-28-2018
I think this is a design issue. I've been able to replicate how the water enters the air filter box, by pouring water along the rain channel on top of the passenger side headlight. The water runs down between the grill and the headlight then drips/pours right into the main air intake opening. As stated in an earlier post, there are two drains in case this happens; one in the air box and the other at the lowest portion of the gooseneck tube. In my case, the lower gooseneck drain does not allow enough water to escape. The water level in the gooseneck becomes high enough that it seeps into the air filter box. I normally take my vehicle through a touch less high pressure car wash every other week. I truly believe this is how my air filter is getting wet.
I took the saturated air filter to the dealer to show them this issue. They stated that they have never seen anything like this. They know how fastidious I am and how I treat my vehicles, so there were no questions or implications of me driving it in high water or abusing the vehicle. The dealer had no suggestions how to correct this situation, but recommended that I contact VW customer care. I then contacted VW customer care to see if they have any recommendations as to how to correct this problem. They said I needed to talk with the dealer. I feel like I'm on my own with this.
I don't want to leave it as is, because I'm only asking for problems later. I don't like the deflector contraption used in China that has been posted in this thread. Seems light a half-baked solution to me. IMO, I think there are two things to do that would minimize this issue. First, the drain at the bottom of the gooseneck takes minutes to drain the water out from the gooseneck. If you pop off the drain nipple, it will drain everything out in seconds. Night and day difference. The negative is you will not be able to plunge your vehicle through those super deep puddles. This is not an issue for me. Second, if you could redirect the water running between the headlight and the grill so it doesn’t even drain into the air intake tube. I have a couple ideas on how I would do this, but they would need to be tested first.
So, I'd just like to thank you guys again for pointing this out as I would not have checked on this until the air filter needed to be replaced (60k miles). If your vehicle sits outside in super heavy down pours or you take your car through high pressure car washes, this may happen to you. I don't think this issue is as likely when the vehicle is moving, as the air would direct the water elsewhere. I would highly recommend that you check your air filters and see if you have this issue. $25 on a new VW OEM filter, probably saved me a ton of heart ache! In the future I will be checking my air filter much more often.
Your thoughts?
promogul and saltshaker like this.
