2017 Sport w/Tech Engine Ingested Water - Page 4 - Club Touareg Forums
post #31 of 205 Old 04-19-2018
I suggest you write as concisely as you can to Honest John at The Daily Telegraph and see what he thinks to the 70/30 split.
[email protected]
Also it would be good if you posted on the UK site as this one is fairly US-centric.
www.mytreg.com
post #32 of 205 Old 04-19-2018
Spiegelglatt's Avatar
Second Vehicle: 2007 V6
If we have to deal with this kind of crap, we might as well have a freaking KNN cone filter on. At least it won't get sucked into the freaking turbo. Good grief!
Spiegelglatt is offline
post #33 of 205 Old 04-20-2018
[email protected]
www.mytreg.com
Posted on mytreg, thanks noobytoogy
Cymro333 is offline
post #34 of 205 Old 04-20-2018
Touareg: 2017 V6 FSI
Second Vehicle: 2005 V8
It sounds like this issue can possibly happen after going through a car wash? The place I go to has a high pressure touch free system.
promogul is offline
post #35 of 205 Old 04-20-2018
Quite possibly but mine has never been through a car wash, always hand wash it
Cymro333 is offline
post #36 of 205 Old 04-23-2018
Touareg: 2016 V6 FSI
Here are articles from China regarding the issue and the VW recall in China. The second article raises a lot of questions that VW's solution is half baked. By removing the drain valve it does seem to be replacing one problem with another.
The company will recall some of the imported Volkswagen Touareg car series ? Minagao blog
Touareg owners are skeptical about the recall process and program. Popular exclusive response is not tolerated.
Rob4 is offline
post #37 of 205 Old 04-25-2018
Touareg: 2012 Hybrid
Second Vehicle: VW Bus
I found this subject very interesting! I read all of the post and thought it may be a good idea to check out my air filter and box to see if I may have a problem. I have a 2012 Hybrid with the supercharged engine and did not have very much clearance to remove the cover but did manage to get it out, the front of the filter looked ok but the bottom was moist. After removing the filter it was obvious that I had a problem. The filter media has some type of cheap foam on the back side and it had mostly deteriated and it had partially clogging the drain. I was able to remove the drain pipe and it was all clogged up with deteriated foam junk from the filter, I flushed it out and put it all back together. I am going to purchase a replacement filter this week.
So be warned. I do not think that most service techs when they replace your filter will also remove the drain pipe and remove the junk that is plugging it up. If your lucky they might vacuum the junk out of the box leaving you at risk when you do have an incident getiing water in the air pipe and it not having a way to get out!!!
carlg007 is offline
post #38 of 205 Old 04-26-2018
I am a big OEM guy, but I am considering going to a K&N oil filter drop in over this because the main filter media is more robust. I know all about dirty air intakes from these...especially when they are cleaned and re-oiled, but am reconsidering my view on this filter for this specific application. The more people saying they are experiencing this, and the fact that I have too (wet deteriorated filter). Obviously a clogged drain can be cleaned, but if the filter material itself is clogging... Arrrrrrrrrg!
Anyone running one of these in any Touareg engine configuration? Feedback would be appreciated.
post #39 of 205 Old 04-27-2018
Built4Sin's Avatar
There are dry media filters that you could also look at.
| Cayenne TT Sways |
Built4Sin is online now
post #40 of 205 Old 04-30-2018
I will have to do that, was researching and just not comfortable with the amount of dirt that the k&n let's by.
Conversely I could also just by a boat load of OEM filters and switch them out more frequently than once a year like I am now. I don't drive much anymore, so that equates to once every 5,000-9,000 miles depending on Treg.
