V10 camshaft timing problems - Club Touareg Forums
  • 1 Post By noobytoogy
post #1 of 3 Old 05-20-2019 Thread Starter
I have a 04 touareg with the v10 tdi in.200k on it. I picked it up over a year ago cheap because it was misfiring under throttle. It had the typical worn out camshafts. Always wanted one ever since I worked as a VW tech for a couple years.
Replaced the camshafts - not OE but from place out of the UK. All new lifters, bearings ect. I had access to the OEM timing tools at the time, except the camshaft holder kit. Ordered that. Anyway, it all went very smooth.
After about a month of driving it (it was driving great), it started having a harder time starting and was setting fault for p0341 - implausible camshaft signal. Eventually, it would not start at all. Disconnecting the camshaft sensor would allow it to start up and drive into the shop.
I did not think to replace the camshaft bolts ( Large triple square that holds gear) because I forgot to order them and I only had the weekend to finish my vehicle when I tore into it. This was at the shop I worked at, and had to go out on Monday. I was thinking because I didn't replace those, maybe the timing moved. * I did use new friction washers.
Decided I would drop the motor again, 2nd time around is always considerably faster and easier. This time around made sure to use all new camshaft bolts and friction washers again. Retimed engine and off I went. Ran great.
Drove it for about 6 months, no issues. Then it started happening again. Again, setting fault: p0341 - Camshaft Position Sensor (g40) Implausible signal. Only sets fault on startup. Not a hard fault while running.
Frustrated, I parked it for a while and forgot about it.
Now that winter is over and it's warmer, started tinkering on it again. I checked continuity in all the wiring from ecu1 and ecu 2 to the sensor, all good. Backprobed ECU and connected lab scope to the cam sensor, to see what the computer was reading. Showed a nice clean square wave signal. So that should prove wiring and sensor is good. I have no way of confirming if the timing is correct, via vagcom.
Looks like it needs to come apart again. But, I no longer have access to lift, so will be doing this engine in - which I did read is possible?
I also no longer have access to service manuals, anyone have the procedure for timing? and torque specs. I don't remember the procedure that well. Fleet maintenance mechanic now, and no need for alldata - or even a lift. Just a drive on lift.
So what else can be going on, to cause the timing to slip? I know for fact, everything was torqued to spec. New stretch bolts and friction rings. The timing was triple and quadruple checked before final torque. And after. No obvious wear on the camshaft gear. What am I missing? I'm not for sure if this was an issue before replacing camshafts, as the misfire was pretty bad and I didn't drive it much. The misfire was a bad vibration under throttle. Any thoughts?
bigskytk is offline
post #2 of 3 Old 05-21-2019
Buy an hour of time here and using your VIN download all the tech stuff you need for your specific car.
https://erwin.volkswagen.de/erwin/showHome.do
Also this thread might help you too - the best V10 strip that I have seen over the years!
https://www.google.com/amp/s/www.clu...9.html%3famp=1
marktdi likes this.
post #3 of 3 Old 4 Weeks Ago
Multiple v10tdi owner
Blownvette's Avatar
Second Vehicle: 2004 V10 TDI
From what you have said, sounds like everything was set up correctly and checked... the next thing to do is check if the plasma liners have delaminated. It would give a similar fault.
A quick compression check would be in order. Good luck...
Blownvette is offline
TIMING BELT FAQ nickm Touareg DIY and Technical Info - DO NOT POST NEW THREADS ASKING QUESTIONS 59 09-23-2017 01:37 AM
V10 Colt Camshafts Ready; Need Timing Tools Now! Redneck Truck Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 21 09-08-2016 11:48 AM
Problems after Timing belt Change wrestlefan775 New Member Introductions 4 04-12-2015 01:15 AM
V10 timing gears johnboysmurf General Maintenance & Repair 11 08-17-2011 11:15 PM
Television and other problems V10 simon911 Australia & New Zealand 1 08-23-2007 06:08 AM
