V10 Battery Information - Club Touareg Forums
post #1 of 48 Old 06-07-2012 Thread Starter
The following represents research I've done on the two batteries required for the V10 TDI. Most place's websites didn't show batteries for the Touareg V10 TDI, and some showed incorrect information. So I visited the various parts stores in person armed with the battery specs and a note pad and found the batteries we need ... even if it involved digging through the battery racks myself.
If you discover any other data or corrections to this data, please feel free to respond - I'm not a battery expert. Also, the prices may change regionally or over time.
Compiled Jun 5, 2012.
General Battery specs:
For trunk well: (H8 Series Battery)
Dimensions: 13 3/4” X 7” X 7 1/2”
12V 900 CA , 720 CCA
Under Driver’s Seat: (Group 49 Battery)
Dimensions: 12 3/8 ” (12.4) X 6 7/8” (6.90) X 7 1/2” (7.4
12V 1000 CA, 850 CCA
Top Terminal (Positive Terminal on Right)
Reference numbers: MTP-H7 H7(94R)
Interstate Batteries:
For trunk well:
Product ID:
MTP-49/H8 non-AGM $184.95
Product ID:
MTP-49/H8A AGM $293.95
Cranking Amps:
900
Cold Cranking Amps:
720
Voltage:
12
Weight:
52
Width:
6.89
Length:
13.94
Height:
7.48
Product ID:
MTP-95R/H9 $196.95
Voltage:
12
Weight:
63.9
Width:
6.94
Length:
15.56
Height:
7.5
AutoZone:
For Trunk Well:
H8-DLG Duralast Gold $134.99
900 CA / 760 CCA
49-DL $109.99
1000 CA / 850 CCA
13 15/16 x 6 7/8 x 7 1/2
94R – DLG $164.99
990 CA / 790 CCA
O’Reilly:
For Trunk Well:
SuperStart 49 EXT(AGM) $169.99
Superstart 49 EXT $124.99
94R-EXT $164.99
CA 910 / 765 CCA
Volkswagen Dealerships:
Here's the part numbers - not sure which goes where:
Part # 000915105DLDSP $199.00
85aH, 480 Amp
AND
Part # 000915105CEDSP $225.00
110aH and 520 Amps
(both special order items)
Pep Boys:
For trunk well:
H6-770 PP $153.99
Cranking Amps: 900
Cold Cranking Amps: 770
(Not as wide as stock battery)
49-850 B $108.99
Cranking Amps: 1000
Cold Cranking Amps: 850
(Battery Terminals not reversed)
94R-730B $ 158.99
Cranking Amps: 875
Cold Cranking Amps: 730
Wal-Mart:
For trunk well:
Everstart Max
Maxx-H8 #14 $107.96
990 CA / 760 CCA
Maxx-94R $109
900CA / 765 CCA
12.44 x 6.94 x 7.48
Batteries Plus:
For trunk well:
SLI 49-H8M $125.00
??? CA / 900 CCA
SLI 94R-H7 $149.99
??? CA / 765 CCA
NAPA:
For trunk well:
75-49 $129.00
1080 CA / 900 CCA
75-94R $169.00
910 CA / 765 CCA
Please add comments and corrections. I make no recommendations - just presented this list for the benefit of all.
LovemyV10 likes this.
EulessDave is offline
post #2 of 48 Old 06-07-2012
ArtieLange's Avatar
I have already replaced my front one, but THANK YOU for doing this. Very valuable post.
2004 V10, lots of stuff
1987 D21 lifted 6", 33's on 15x12
ArtieLange is offline
post #3 of 48 Old 06-08-2012
Touareg: 2007 V10 TDI
Thanks for the info. I have it printed and filed with my other Treg stuff.
Mike N is offline
post #4 of 48 Old 12-16-2013 Thread Starter
Interstate batteries
Just replaced my batteries with two from Interstate Batteries. Their website has the specs, and they are also listed above. Their H9 battery was bigger than the WalMart brand battery that was in there, so I didn't think it would fit under the front seat. But there's a lot of room under there. I've attached photos of the two batteries.
FYI - the WalMart batteries died after 20 months. I could have gotten a pro-rated value applied to a new purchase (25%) but I bit the bullet and went with a higher grade battery. The Interstate brand has a 3 year full replacement warranty and a 6 year service life guarantee.
ID:	37041   Click image for larger version
David W. Allen, GISP
2004 Touareg V10 TDI
1998 New Beetle TDI
1974 Thing
post #5 of 48 Old 12-16-2013
Where's the little wire thingummy in your tool kit for pulling the plastic caps off the wheel lugs?
And I hope you got your vacuum cleaner out before you dropped the driver's seat back down!
post #6 of 48 Old 12-17-2013 Thread Starter
When I got it used, the wire thingy and the air hose were gone. I made a new wire thingy out of bailing wire, but it's in the Beetle.
I have the deep fit WeatherTec mats so when you lift them there's always a little buildup. I vacuumed (or hoovered) before replacing them.
1998 New Beetle TDI
1974 Thing
post #7 of 48 Old 12-17-2013
Well you'd better make another thingummy!
Glad to hear you Dysoned the carpets too.
Funny how a product becomes synonymous with a task like "Hoover".
I worked with a company called Redler that made chain conveyors for moving granular products, notably, in my business, grain - wheat, barley, oats. I subsequently learnt that in Africa a chain conveyor was called a redler regardless of who made it!
post #8 of 48 Old 11-12-2014
Still Plays With Cars
aircooled's Avatar
Second Vehicle: 2006 V10 TDI
Bump, and I will move and sticky this to the top of the TDI Forum!
Please read our Club Touareg
and our
aircooled is offline
post #9 of 48 Old 11-13-2014
kinda surprised nobody addressed the issue of changing both batteries even if just one is bad?
joe feuerstein aka TOURQUE DORK
2006 v-10 wheat-beige lux package
joefeuerstein is offline
post #10 of 48 Old 11-13-2014
I gave up on that discussion a while back
If people want to throw money away on both batteries its their choice.
Regards
Drag
dragline1570 is offline
double battery? is it standard on v10? reddy Touareg Exterior Mods 2 03-05-2019 12:40 PM
V10 Battery replacement questions DicknNancy General Maintenance & Repair 12 11-01-2012 03:47 PM
Second Battery in anything other than a V10 bobzed57 Touareg Exterior Mods 9 09-27-2010 10:15 AM
Which Battery Does What on a V10 Bails General Maintenance & Repair 8 03-22-2009 04:33 PM
V10 Battery Cables bobzed57 Touareg Exterior Mods 0 02-05-2008 01:41 AM
