Trouble Code P1456 EGT Limit - 2006 V10 - Club Touareg Forums
post #1 of 25 Old 11-07-2011 Thread Starter
Still Plays With Cars
aircooled's Avatar
Second Vehicle: 2006 V10 TDI
Today, the V10 threw a MIL. Bless my wife who called me to ask what the light was and if she needed to pull over and shut her down. The readout from the VCDS follows. Anyone have any idea if the EGT sensors are possible to access with the engine in? So far, the fault count is "1", so this could be a spurious fault, but more miles will tell is this is an isolated incident or not. Could this be a sign of a clogging DPF? Which side is "Bank 1"? Does anyone know how to measure EGT with VCDS?
Address 01: Engine Labels: None
Part No SW: 070 906 016 CQ HW: 028 101 196 2
Component: V10 5,0L EDCG000AGMª8472
Revision: --H02---
Coding: 0060575
1 Fault Found:
005206 - Exhaust Gas Temp Regulation for Bank 1: Limit Reached
P1456 - 000 - -
Freeze Frame:
RPM: 1344 /min
Speed: 64.3 km/h
Inj. Quantity: 15.2 mg/str
Temperature: 432.0°C
Duty Cycle: 18.5 %
Temperature: 20.7°C
Please read our Club Touareg
and our
aircooled is offline
post #2 of 25 Old 04-17-2012 Thread Starter
aircooled's Avatar
I continue to intermittently receive this. Does anyone have any insight?
and our
post #3 of 25 Old 04-18-2012 Thread Starter
aircooled's Avatar
OK, I was at the dealership today. This code is for an EGT sensor for the DPF filer. Not sure exactly where in the exhause system it meters, but the sensor is said to be in top (!) of the transmission. Getting to it will require dropping the transmission cross member to allow the transmission the required room to replace the sensor.
Also, Bank 1 refers to the (vehicle) right side of the engine.
and our
post #4 of 25 Old 10-14-2012
Lifetime Member
My '06 V10 complained about the same thing a week ago. I just had a chance to hook the VAG to it and saw the same reading as yours. Did you end up fixing yours? I am still covered by extended warranty but am curious what will have to come off to get to it. Did they end up dropping the transmission?
PS. My readings for those that care:
P1456 - 000 - Limit Reached - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 3
Mileage: 160485 km
Time Indication: 0
Freeze Frame:
RPM: 1659 /min
Speed: 100.0 km/h
Inj. Quantity: 17.9 mg/str
Temperature: 444.0°C
Duty Cycle: 15.4 %
Temperature: 25.2°C
Readiness: 1 1 0 0 0
'06 Black/Beige V10
Mods: Push Start/Stop, rear fog lights, euro light switch, O.CT ECU flash, parking heater (timer and T91 remote), heated steering wheel (paddles as a bonus), Parrot "factory" bluetooth.
V10TDI is offline
post #5 of 25 Old 11-02-2013
Touareg: 2007 V10 TDI
I too just got this error on my 07 V10. Did either of you get this fixed...I know it does not impact drivability but it does cause emissions inspection failure.
orttauq is offline
post #6 of 25 Old 11-02-2013
Oops-I just noticed that age of this thread so now I know a fix must have been found.
orttauq is offline
post #7 of 25 Old 11-01-2014
anyone ever find a solution for this?
it is indeed impacting my driveability (rough idling, weird shifting, mild surging, etc...). at first i thought it was my fuel filter so i've got one on order. and then i got the check engine light and this was the code thrown.
any insight would be appreciated.
2006 Touareg V10 TDI
2015 Golf Sportwagen TDI
2007 Mazda CX-9-sold
2003 BMW 325i-sold
2004 V10-sold
2003 V6 Passat-sold
2002 V6 Passat-sold
numerous GM products-sold
a1cmaw is offline
post #8 of 25 Old 05-09-2019
Any update on the fix?
My baby: 1969 300SEL 6.3
TouaregNut is offline
post #9 of 25 Old 4 Weeks Ago
Do I need to change the EGT sender unit?
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 281745 km
Time Indication: 0
Freeze Frame:
RPM: 2016 /min
Speed: 121.4 km/h
Inj. Quantity: 17.6 mg/str
Temperature: 516.0°C
Duty Cycle: 0.0 %
Temperature: 21.6°C
Readiness: 0 0 0 0 0
post #10 of 25 Old 4 Weeks Ago
Do you have a before and after sensor on your system? Your reported temp is 100deg C higher than the others who previously posted.
It sounds to me like your DPF is trying to burn itself down.... Due to your milage it is not unreasonable to think that your DPF is full.
I would do more troubleshooting because you more than likely need more than just an EGT sensor.
egt , error , fault , service
V10 EGT fault tightt General Maintenance & Repair 28 01-30-2018 09:39 AM
Trouble Code P0420 Brown Irishman General Maintenance & Repair 12 08-26-2017 11:19 AM
Touareg V10 Engine Fault Code grateful_carl General Maintenance & Repair 8 01-01-2012 03:51 PM
Airbag Fault...code 01587 on 2006 Treg V6 BluMkIIIVRSix General Maintenance & Repair 1 02-24-2011 10:19 AM
air bag fault code hard code? vag come erase? brh8 General Maintenance & Repair 2 03-09-2010 04:08 PM
