Transfer Box Identification - Club Touareg Forums
post #1 of 7 Old 02-14-2019 Thread Starter
Hi there,
I have just had my transfer box blow up and need to replace it, my mechanic has told me the numbers on the transfer case are 0ad 341 011g 485jxf031298nvg . I have found a few transfer cases online those being 0ad341012, 0AD341012D, 0AD341011CX.
My question is are they all interchangeable? as the cases seem identical and if not what are the differences?.
Thanks craig
craiggibbs is offline
post #2 of 7 Old 02-14-2019
What are the vehicle details?
post #3 of 7 Old 02-14-2019
At the minimum we need to know year and engine. The transfercases have different neck lengths depending on engine. If your current box is 011G, you can only use 011G, any other number (012, 012D, 011CX) is for a different engine.
Parts fun fact: the X modifier in any VW/Audi part number (as in 011CX) indicates a rebuilt item.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
post #4 of 7 Old 02-14-2019
Yeah right!
Well, I just learned something!
post #5 of 7 Old 02-19-2019
bmannator's Avatar
Second Vehicle: 2004 V8
After doing a quick search, it seems Touareg transfer cases are somewhat interchangeable. At least, that's what the search results indicate. I got this;
TRANSFER CASE / GEAR BOX 0AD341011L
$400.00
ADD TO CART
Add to Wishlist
Brand: Genuine / OEM
Compatible Part #s:0AD341011G, 0AD341011, 0AD341012K, 0AD341012F, 0AD341012E, 0AD341011H, 0AD341012T, 0AD341012J, 0AD341012A, 0AD341010S, 0AD341011LX, 0AD341011HX, 0AD341012JX, 0AD341012TX
It was also noted that the above numbers were suitable for the 3.2, 4.2, 4.9V10 engines.
Something else you might consider is in the case of the transmission. it comes out of the car, along with the engine, transfer case, and the front differential. The whole assembly drops out the bottom of the car while the rest of the vehicle is supported.
It might be possible to get the transfer case out without going to all this trouble but that's how the dealer would do it.
It wouldn't hurt to make sure it can be removed separately before you proceed.
2013 TDI Lux Black over cornsilk, Wifey's response to the Mercedes below
2009 Merc ML63 AMG Black on black, passes anything but a gas station
2004 Touareg 4.2 w/air ride. Too bad you can't get a T3 equipped like this in No.America
2004 BMW R1150GS 2 wheel version of a Touareg
bmannator is offline
post #6 of 7 Old 02-19-2019
$400.00
ADD TO CART
Add to Wishlist
His transfercase code is GTK or HAQ, the one you listed (011L) has code GLH or HAU. They are different.
The transfercase is easily removable from the transmission on its own, without having to remove the engine or transmission. The service manual even indicates this, so I'm not sure where you got your incorrect information from. It actually comes out quite easily.
post #7 of 7 Old 02-19-2019
bmannator's Avatar
The 011L is the current transfer case version. It is listed as a compatible replacement with the 011G case (according to the part listing) which could be wrong. However, when I Googled the 011G case, the result comes back listing the 011L as the current case. It wouldn't be the first time Google (or myself) made a mistake.
If the case comes out separately, all the better. I just thought it would be a good idea to know the scope of the repair beforehand.
Transfer box issues & identification kuchie Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 1 01-08-2016 02:47 AM
transfer box stepper motor. label info Smallboy Engine, Transmission and Exhaust 1 07-06-2015 10:55 AM
Transfer Box Possible Fault pioneer General Maintenance & Repair 6 05-15-2015 04:25 PM
Transfer box mark62 Engine, Transmission and Exhaust 3 01-30-2014 08:30 AM
Replace Transfer Case / Box Motor or Entire Transfer Case Nvrgvup Engine, Transmission and Exhaust 8 02-02-2013 12:29 PM
