Trans quick Re-Learn Procedure - Club Touareg Forums
Old 08-30-2018 Thread Starter
Second Vehicle: 2006 V8
This is slightly different than what I call the Noobytoogy trans reset, so I'd thought that I would post it up here.
This comes from a transmission repair group that send out technical bulletins, how to's, etc.. that I follow.
1. Turn the key on, but donít start the engine.
2. Move the gear shifter from Park to Drive.
3. Press the gas pedal all the way down,making sure nothing is between the pedal and floor, like a floor mat. (added that you should feel a little resistance towards the bottom as you hit the kick down switch)
4. Hold the gas pedal down for at least 30 seconds.
5. While still holding the gas pedal down,move the shifter back into Park.
6. Turn the key off.
Anyone want to give it a shot?
The Nooby one seems to be working well, just curious to see if this does anything differently...
yrktreg is offline
I'll add this to LOL
The procedure is now complete.
Test drive the vehicle to confirm that shifting has improved.
You can use this procedure on any Volkswagen or Audi that has an electronically controlled transmission
yrktreg is offline
Old 08-30-2018
Where is the documentation for this procedure?
Regards
Drag
dragline1570 is offline
Old 08-31-2018 Thread Starter
Regards
Drag
I'm not sure I understand..??
It's in the first post
yrktreg is offline
Old 09-01-2018
It just like I have more than once about the so called std reset of holding your foot down.
The one you have posted the steps for is just a variation on the std version.
What I mean is where is this written either in VW documents, Aisin documents or some other company documents?
To me this reset is just one of those perpetuated myths that keeps getting put up, and no one has ever produced a formal document!
regards
Drag
Old 09-01-2018 Thread Starter
regards
Drag
IIRC this was from an AAMCO document. I can look for it later if you would like.
This is known as a quick reset, you can do a full reset aka adaptation with the factory tools, or VCDS.
yrktreg is offline
Old 09-01-2018
Thing is they work. Now whether that's mere perception or what, I'm not fussed!
My version came years ago directly from the VW Touareg trained technician who looked after my old motor and that was good enough for me!!
The one thing that's always omitted is that you should look for faults using VCDS or the equivalent before the reset.
Old 09-01-2018
Please find the document so I can put this to bed once and for all.
regards
Drag
Old 09-01-2018
Here is an old one.
https://www.scribd.com/doc/52799079/...earn-Procedure
Another from https://www.snapon.com/Files/Diagnos...AZ0031B01D.pdf
Important Tips for Transmission Basic Settings
ē Basic Settings 04/000 also resets transmission learned shifting adaptation to 0 or base point. Some early transmissions have no Basic Setting selection. To reset adaptation on these, switch the ignition on without starting the engine and press the accelerator all the way to the floor, turn ignition off, let up on accelerator, restart engine. Drive the car and monitor shifting. It should shift at default with no learning. Early transmissions may require an extended road test to learn new shift adaptation.
2016 Lux, Black Oak Brown
MarkinGA is offline
