Touareg 2007 TDI Turbo sensor light on - Club Touareg Forums
post #1 of 13 Old 02-22-2018 Thread Starter
Touareg: 2007 V6 TDI
Hi Enthusiasts,
My 2007 Touareg has done 230,000 km and the glow plug light with audible "dinging" comes on randomly and stops after 5 minutes. The cruise control turns off and the car will revert to gear 5 in auto, but gear 6 in manual. There is a loss of power. The mechanic put the computer across it and tells me it could be the sensor or the turbo. Replacement of either one is necessary.
Would you replace just the sensor $1030 or the whole turbo $4480?
Any suggestions would be appreciated.
Luke G is offline
post #2 of 13 Old 02-22-2018
seafarer28's Avatar
When you say "sensor" do you mean the turbo controller or something else?
If you decide to replace the turbocharger you know that you need not to go with a dealer sourced VW turbo don't you?
A few of us after some turbo issues decided to replace the turbo with a new Garrett (OEM turbocharger supplier to VW) unit which is exactly the same as OEM except it does not have the "VW" logo stamped on it with quite a substantial cost saving and I can attest that after going down that route some 20K ago using a new in box Garrett "GTB2260VK" turbocharger my engine has not skipped a beat.
The turbocharger was sourced from Denco Diesel (https://www.dencodiesel.com/) at a substantial cost saving and the whole job cost less than AUD$3K.
Suggest you read https://www.clubtouareg.com/forums/f9...km-269585.html as Stuart also replaced his using the same unit and this is his tread.
Good luck!
TonyB
MY08 V6TDi, Campanella White
seafarer28 is offline
The Following User Says Thank You to seafarer28 For This Useful Post:
Luke G (02-22-2018)
post #3 of 13 Old 02-22-2018
Touareg: 2007 V6
There are even cheaper ways too, if you know what to do:
> You can replace the actuator only
> You can rebuild a worn out turbo with a new CHRA (core housing rotating assembly)
Regardless, the symptoms you describe do not indicate turbocharger mechanical failure. Seek further diagnosis. Get a VCDS scan and post it up.
There is no reason that a turbocharger failure would cause the car to stay in 5th or 6th gear.
gldgti is offline
The Following User Says Thank You to gldgti For This Useful Post:
Luke G (02-22-2018)
post #4 of 13 Old 02-22-2018
OrangeOkie's Avatar
It is threads like this that make this the greatest Treg forum in the world.
Current Fleet:
OrangeOkie is offline
The Following User Says Thank You to OrangeOkie For This Useful Post:
Luke G (02-22-2018)
post #5 of 13 Old 02-22-2018
Originally Posted by Luke G View Post
Hi Enthusiasts,
What are the exact fault codes ??
regards
Drag
dragline1570 is offline
The Following User Says Thank You to dragline1570 For This Useful Post:
Luke G (02-22-2018)
post #6 of 13 Old 02-22-2018 Thread Starter
Hi Enthusiasts,
I am blown away with the promptness and depth of information provided. Thank you. It prompted me to consider that the problem is electrical (sensor) and not turbo (mechanical) as when the light isn't on, the turbo goes like a rocket. Armed with this thought and your confidence, I spoke with my mechanic and he agreed. I am having the sensor changed and while there, he will investigate the state of the turbo. If need be, we will change it as well. To my surprise he suggested the Garret at a better price.
It is so much easier to make decisions and talk to mechanics when you have some knowledge. Thanks Reggie warriors. Much appreciated.
Luke G is offline
post #7 of 13 Old 03-06-2018 Thread Starter
Hi Everyone,
Tthe "turbo sensor" situation has turned into a real debacle. I thought is was important to warn you of the trap for young players. The VW workshop fitted the sensor and as they have never seen this problem before, did not know that there is a special "vacuum calibrating" tool that is required to align the sensor and the turbo. Would you believe it, this tool is not available in Western Australia (WA) and needs to be dispatched via Sydney, New South Wales.
WA stands for Wait Awhile as it has been over a week and still no tool.
I should have told them about the tool, but I presumed they would know better than me.
Lesson for the day - don't be afraid to question the mechanics knowledge or pass yours on.
Luke G is offline
post #8 of 13 Old 03-06-2018
seafarer28's Avatar
Hi Luke,
When you say " The VW workshop fitted the sensor" do you mean a VW dealer or non-VW dealer, say "general" workshop?
I assume you mean the latter as (AFAIK) VW dealers will not change the sensor but will only replace the turbocharger complete with sensor.
TonyB
Luke G (03-06-2018)
post #9 of 13 Old 03-06-2018 Thread Starter
Hi Seafarer28,
Yes you are correct it was done through a VW dealership as my mechanic did not have access to the "tool". Reading your enhancements on your Touareg, it must be some awesome beast.
Luke G is offline
post #10 of 13 Old 03-06-2018
Hi Everyone,
How the hell do you need a vacuum calibration tool for a V6 turbo charger ??
Maybe needed on a R5 with a vacuum controlled turbo but not a electronic actuator ????
regards
Drag
