Tandem Pump Rebuild/Replace - Club Touareg Forums
post #1 of 5 Old 04-11-2018 Thread Starter
Touareg: 2007 V10 TDI
Just a few quick thoughts from completing a rebuild on the right/passenger side tandem pump - without engine removal. First and foremost, I have worked on many cars over the past 15 years which range from small stuff to full-on rebuilding engines and replacing transmissions and this was one would rank really high on my list of hard jobs. It's not for everyone, so if you do it just remember that it can be done without engine removal and I'd recommend having the help of someone that can at least take pictures of how things disassemble.
In no particular order, here are my thoughts on the job:
Step one. Ask your dealer what they will charge to do it before you start, that way you can feel good about all of the work you are about to do.
Everything is fragile. EVERYTHING.
The wiring that VW, Audi, and Porsche use are extremely fragile because it is made with soybean oil - I'm not joking. The Germans might be good at a lot of things, but automotive wiring is not on the list. Having said that, be careful with your wiring harness and the 4 or 5 things you will have to unplug.
The bolts are a steel composite and are designed for single use. So my advise would be to buy a couple intake manifold bolts and various other bolts to have on hand. Also, get acclimated with the ballpoint extra long metric allen wrenches. You might want to check out Northern Tool and get both the long and smaller set.
I ordered the rebuild kit on eBay and it came from Latvia and took 3 weeks to get. During the disappointing wait, I looked for the kit from an American seller and there weren't any.
If you do the rebuild which will save you about $500:
The internal T30 bolts on the fuel side of the pump were very hard to get off. I had to drill the heads off of two of the bolts, so if you struggle it's normal. The center seal that separates the vacuum side from the fuel side can be tapped out with a flat head screwdriver and the new pressed in with a same sized socket as the outer seal diameter and hammer. It would probably be wise to put a very small amount of grease on the center of the seal - I mean very very very light coat.
Don't ask me how I know, but do not get any cleaning solution, especially WD 40 on the rubber gasket on the tandem pump, because the rubber will stretch/expand and the gasket becomes useless.
There are only 3 bolts holding the pump on the head. Two 6 MM allen heads and one 10 MM bolt. Before installing aggressively clean the surface where the pump mounts. Use an endoscope or mirror to look at it before reinstalling.
Every surface that has a gasket should be cleaned to the point of looking new. You don't want to spend X number of hours to have to do the job again because of a leak. The safest way is cleaning solutions and terry cloths. If you have the experience you can use a solution and brass bristled brush, but be careful. On the intake manifold I used wire brushes and the 600 grit sandpaper, which made the surface look new, but if you overdo it you can cause serious damage with the brush or low grain sandpaper.
The bottom screws to the center EGR cooler hub are very hard to get out and equally hard on the reassembly. I used a small magnet and the really long (about 6 - 7 inches) 6mm ball ended allen wrench from Northen Tool and it took about 30 - 40 minutes to get all of them in.
On the tandem pump, the center key that mates with the camshaft have to line up or the pump will NOT go back on. I think I have read somewhere that you should mark or make note of where it was upon removal, which is a complete joke. I put blue paint on mine and it was not helpful for this reason: the center bar has to line up exactly with the camshaft because it's square in shape and cannot correct itself if your a little off. Basically, you either have it lined up or you don't. Also, you are leaned over the motor and cannot see anything so you are relying on whatever you can feel. Even with the paint, I had to turn the key on the pump fractions of an mm to get it perfect and it took about an hour.
All of the gaskets are single uses which aren't unusual. On just the Tandem pump job you will at minimum need: the pump or rebuild kit, the EGR to throttle o ring, the throttle to intake manifold o ring, intake manifold gasket, the EGR hub gasket, and I would strongly recommend new bolts for the EGR hub and the intake manifold.
While I'm sure it was more specific to my case the engine will need to turn over a lot to prime the pumps. The reason my case was different was that I replaced all the seals on the oil cooler so I had to take the fuel rails off which means the pumps it has to fill the rails up before you get your diesel rumble. While I didn't time it, the engine turned over for a solid 40-50 seconds before it started.
If you decide to do it, good luck and be prepared to have two days to work on it. If you break something and have to go to the dealer, the chances are slim that they have it in stock and you might have to wait a few days for gaskets, bolts or whatever. In my case, the dealer can get your parts the next day (depending on the part) if ordered before 1 PM Monday through Friday. If on Saturday you have to wait until Tuesday.
middleton61 is offline
post #2 of 5 Old 04-11-2018
4ePikanini's Avatar
Touareg: 2005 R5 TDI
any chance you took some pics?
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
post #3 of 5 Old 04-12-2018
Good work on all that.
Just a few comment to add.
- I rebuilt both my pumps and pressure tested the seals before install especially the tandem pump seal to make sure no diesel gets into the vacuum area. (that would be argggggg)
- I also pressure tested both fuel rails after re-fitment to ensure no leaks.
- So much much easier when engine is out but clearly not required. but with a hoist engine and experience engines can be removed in less than 6 hrs.
- I use https://www.autozone.com/sealants-gl...ant/520940_0_0 on the steel pump to head gasket.
Issue with the leak is a poor setup from VW with only 3 blots that do not hold the pump evenly and the small oil feed port is very close to the gasket edge.
This oil port is only on the tandem pump as it supplies oil to the vacuum section of the pump.
This is an oil leak waiting to happen on all V10 engines.
Again well done
regards
Drag
ID:	211841   Click image for larger version
dragline1570 is offline
post #4 of 5 Old 04-12-2018 Thread Starter
Again well done
regards
Drag
Great pictures. Here are a few I have.
On the diesel side, it might have had a leak or it was bound to happen based on the seal surface of the black plate. It wouldn't be bad to pressure test the pumps and lines.
I've done several gas fuel rails and if you are careful and everything goes on evenly the tend to never leak. However, on this V10 you have two fuel inlets so you need to use a dental mirror to ensure that the rail is setting completely over the o-rings. If you don't and it's uneven, you will damage the aluminum rails by tightening the bolts. Also, you can take a q-tip and put an un-noticeable amount of grease on the inside of the rail to make the O-rings slide on a little easier. To clarify I mean you should not be able to tell that you have grease on the inside of the fuel rail, but it has a very light coating.
ID:	211865   Click image for larger version
post #5 of 5 Old 04-12-2018 Thread Starter
Again well done
regards
Drag
Drag,
On this repair, I could not remember or find where this wiring bracket mounts on the back of the engine/firewall. It has a bolt/screw hole. Can you help me out on this? I currently have it zip tied out of the way and it's the only thing that didn't get the proper attention on this job...
