Stability System Tuning - Club Touareg Forums
post #1 of 9 Old 04-09-2019 Thread Starter
Supporting Member
Does anyone know if there is a way to tune the stability system on the Touareg T3? I'm curious if it is running the same program as the Cayenne.
NTDI is online now
post #2 of 9 Old 04-09-2019
I don't immediately recall anyone doing such a thing.
If I am remembering previous posts about this correctly, then the difference between the Porsche Touareg and the VW Cayenne [sic!], is that the Touareg uses a 50/50 front/rear power distribution set up whilst the Cayenne is rear biased at 38/62 and that the Touareg's transmission is somehow "forced" into the 50/50 split electronically.
Others will hopefully be able to explain this much better, but if the split is indeed controlled electronically then perhaps it is possible to reflash whatever needs reflashing with the Porker software?
post #3 of 9 Old 04-09-2019
What exactly do you mean, "tune the stability system"? Do you want to adjust when the traction control takes over? How aggressive it is? I'm certain none of that is "tuneable".
The T1/T2 and Cayene had 4xMotion which had a transfercase set up with 38/62 mechanical power bias and a wet clutch for the bias shift when needed. VW changed their software to make the transfercase run at 50/50 all the time by applying the centre clutch. This is what caused the dreaded binding/stepper motor failure as it was always engaged.
The OP lives in the US and has a T3, which has a purely mechanical Torsen centre diff; and thus, is not tuneable at all.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is offline
post #4 of 9 Old 04-09-2019 Thread Starter
Supporting Member
Regarding the diff you are correct.
But for example the Audi S3 and Audi S4 allow the rear to step out a few degrees (oversteer) before the stability system steps in.
The Cayenne I presume is tuned the same way.
The US T3 has the Torsen center diff which I presume is pre-biased at 40/60 split.
My question is really about the rest of the stability system behavior not just the diff.
NTDI is online now
post #5 of 9 Old 04-09-2019
Two too many presumes in there!
post #6 of 9 Old 04-09-2019
I was forgetting the US didn't get proper Touaregs after Generation 1!
post #7 of 9 Old 04-09-2019
Second Vehicle: Old heap
The ESP program can be turned off by selecting 'off-road' mode then holding down the traction control button for 3-5s. I always thought it would be nice to modify the 'off-road' parameters to suit my needs.
DeepWoods is offline
post #8 of 9 Old 04-09-2019 Thread Starter
Supporting Member
One is too many?
NTDI is online now
post #9 of 9 Old 04-09-2019 Thread Starter
Supporting Member
In this case I’m not looking for off-road. Just some oversteer if it’s even possible.
There are some nice videos of Cayennes with a little oversteer. Just wondering if the Touareg can be configured to do the same.
NTDI is online now
Chip for V6 180kW - Sydney bion Australia & New Zealand 15 01-04-2018 01:20 PM
Diesel Chip - whether to buy Australian or Overseas models... mattcoll Australia & New Zealand 33 03-09-2015 12:40 AM
2010+2011 Touareg TDI tuning. Piggyback ECU. CustomSpooling Touareg Exterior Mods 23 03-26-2012 12:33 PM
Which Sound System is Which? sportwa72 Mobile Electronics and In Car Entertainment 15 09-21-2008 01:32 PM
For Sale: 2004 Touareg V8 with Nav system & Tow package roadtrippers Classifieds Archive 0 06-07-2008 11:32 AM
