R50V10 light throttle miss - Club Touareg Forums
post #1 of 10 Old 02-24-2019 Thread Starter
Touareg: 2008 V10 TDI
Hi Guys
I have an issue with a very slight misfire / rough running of my 2008 R50 V10. Problem is worst at very light throttle around 1300 RPM in 6th gear. Not easy to achieve this combination. Also occurs with light throttle in 5th gear 1500 RPM. Just feels like a shudder. Drop a gear and all is OK. Engine performance with throttle on is perfect. ( love a V10 twin turbo)
Checked system with VAG-Com. no errors. Drove the car with data feed from VAG-com running and the engine is very lean on both banks when the problem occurs. I immediately changed the fuel filter. Same problem.
I am thinking the fuel pressure from the mechanical pumps is too low at these very low RPMS causing a lean miss?
Any thoughts, advise, experience would be appreciated.
Just some car info. Camshafts changed about 15000KM ago to colt. No cats or DPFs. ECU's re-flashed to suit. Custom tail shaft. Car is used mainly for towing and the problem less obvious as I normally run the trans in manual 5th. Normally have more throttle on while towing also.
2008 R50
Ecca is offline
post #2 of 10 Old 02-24-2019
4ePikanini's Avatar
Touareg: 2005 R5 TDI
I reckon the reflash needs a tweak.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is online now
post #3 of 10 Old 02-24-2019
seafarer28's Avatar
As was reading your post I thought could be tailshaft related but then I read further so........ please tell us more about your custom tail shaft.
TonyB
MY08 V6TDi, Campanella White
seafarer28 is online now
post #4 of 10 Old 02-25-2019 Thread Starter
I am sure a tweak on the tune would address the problem. I would like to fix the problem. Car was tuned 15000km ago and was running fine until very recently. Something is wrong/broken. Thanks for your thought anyway.
Ecca is offline
post #5 of 10 Old 02-25-2019 Thread Starter
Hi Tony. Cannot tell you much as the tailshaft was in the car when I purchased it. Has a huge plunging center CV with the center bearing. Guessing the previous owner had problems and did not want any more so he went away from the VW carrier.
2008 R50
Ecca is offline
post #6 of 10 Old 02-25-2019
Touareg: 2009 V10 TDI
Second Vehicle: Old heap
Hi there,
I have 2010 R50 with about 160.000 km's. Have owned the car for about 3 years and got light shudders in similar gear/rpm conditions. I have considered it to be "normal" and just kick down the right pedal or change to sport mode.
I have been driving it regularly on german autobahns and its clear the german engineers have designed/optimized the car to be driven hard around 160-200 km/h for extended periods =) The shudder does not occur then.
Interested to find out if this is not normal and if there is a fix. I reset the gear box every once in a while.
Best regards,
Bubbadust
2010 R50 TDI
Other:
2000 1.9 TDI Passat
1991 Golf GTI
1993 Jeep Wrangler
Bubbadust is offline
post #7 of 10 Old 03-05-2019 Thread Starter
Hi guys
Still chasing the problem. I measured the fuel pressure after the fuel filter , before the mechanical pumps. Pressure was 6 psi when I first started the engine cold and about 8psi after 45 minutes of running. Not sure why it changed cold to hot. Warm fuel? This pressure is normal from what I understand. The fuel pressure is very erratic above 1500RPM. I am using a manual gauge and the needle pulses 5 or more psi each side the 8psi where the RPM is increase above 1500. Is this normal ?
R50 V10
Ecca is offline
post #8 of 10 Old 03-06-2019
I have had a US model 2006 V10 for about 2 years and have noticed this exact problem/condition since I bought it. Mine is all stock and I noticed that it is worse when its about to initiate a re-gen. I'm curious if others have experienced it and what was done to resolve it.
2006 Touareg V10, Campanella White/Pure Beige
2013 Golf TDI, 6MT
1980 Kawasaki KZ750
2004 V6 Touareg, Colorado Red/Kristal Gray (sold)
2003 Passat W8 6MT, Black/Black (sold)
GTekW8 is offline
post #9 of 10 Old 03-29-2019 Thread Starter
Hi Guys
I have found my light throttle misfire. Injector is cracked. see picture. This would have allowed fuel to leak out the body and not inject into the cylinder. Found the problem with a high injector correction on cylinder 2 with vag com. Made me look at this injector and found the crack. Has anyone see this before? Like to know why it cracked.
2008 R50
Ecca is offline
post #10 of 10 Old 03-29-2019
Question
Originally Posted by Ecca View Post
Hi Guys
Wow Eric
That is a nasty crack in the injector the photo says it all
Not sure about anyone else but i personally have never seen or heard of that.
Comments from anyone who has ??
Keep us up to date on the replacement injector fixing the issue
Regards
Drag
dragline1570 is offline
Curious for 2015 dome light yuyueyuyue Drivers Lounge 1 07-28-2015 11:49 AM
Help me identify part required. Front light broke , wont come out Crimsonforce General Maintenance & Repair 5 08-03-2014 04:24 PM
Diesel Engine Malfunction Light - Tequila reward! kgofd Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 29 09-22-2011 09:38 AM
EPS LIGHT ON infdegua General Maintenance & Repair 0 09-10-2010 11:03 AM
