r5 2.5 tdi exhaust manifold replacement - Club Touareg Forums
post #1 of 3 Old 08-21-2017 Thread Starter
Touareg: 2004 R5 TDI
hi all,
i'm a bit confused. my exhaust manifold cracked (where it usually does, at the first cylinder), and i decided to get a replacement. i almost ordered one from ebay, but realized that the manifold on the image had the top pipe facing straight back, parallel to the engine's axis, whereas the one on my engine faces slightly outward (at about 45 degrees to the back), so the piping can get around a mysterious part sitting on top of the back of the manifold. i've attached images.
my questions are:
1) what is the mystery part? i've flipped through a bunch of images in google, and not all 2.5 tdi's seem to have it (i guess the ebay part would fit snugly on those)
2) what is the respective part number of the correct type of manifold i need?
3) any ideas that come to mind. i'd like to keep the replacement(/repair?) at low cost
thanks in advance
ID:	189465   Click image for larger version
kolijoco is offline
post #2 of 3 Old 11-16-2017
Touareg: 2004 R5
They don't always have a picture of the exact part.
Often you'll see the same picture for several different engines.
The different part might be for one of the T5 engines.
Flash635 is offline
post #3 of 3 Old 11-16-2017
4ePikanini's Avatar
Touareg: 2005 R5 TDI
The manual R5 has a different EGR cooler
I bought a T5 manifold and deleted the EGR piping and the cooler - The t-piece that feeds the egr cooler gets very brittle and can easily break.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
2.5tdi , exhaust manifold
