NO VW skilled Mechanics in my town so pleasr help (((Lowl pressure, stop engine, owne - Club Touareg Forums
 6Likes
post #1 of 23 Old 05-09-2018 Thread Starter
NO VW skilled Mechanics in my town so pleasr help (((Lowl pressure, stop engine, owner manual)) + gear box rating and jercking off
Hello my brothers ,
Im facing this issue for more than 2 months now
When i start the engine of my 06 VW taoureg v6 , everything sounds good , but when i press the gas accelerator ، this message pop up in the screen and the oil lamp keep blinking , I've changed the engine oil and the fillter lately , still the same , not sloved recently the car started to develop weird low sound when going up through high roads , i mean like a Plateau or something like that . It develop a sound which is soft sound inside the engine and the sound stops when i take my foot off the accelerator
____________
My other issue is the gearbox start jerckin off and rating alot , i feel.like its not switching to the right gear , so i change the gearbox oil which was dark brown almost black with new oil , i didn't change the oil because the deal told me its very risky and may lose my gearbox , so i only changed the oil
After changing the oil i felt amazing change happened , gearbox was shifting smoothly , no rats no jerckin everything was quite good until the next day rats back a again
Note : i insert 6 litters of gearbox oil but i feel that wasn't enough , was it ??
Please help me
Most people here don't know how to deal with german cars
So i need a pro advise and diagnosis
Thank you
Much respect
Sent from my MI MAX 2 using Tapatalk
dr.pain is offline
post #2 of 23 Old 05-14-2018
Second Vehicle: 2006 V8
Where are you located?
Is your check engine light on?
The easiest way for us to help you is if you can someone scan the engine and transmission computer for codes.
dr.pain likes this.
yrktreg is offline
post #3 of 23 Old 05-15-2018 Thread Starter
Thank you sir
Ill scan it and then ill send you thr codes
Sudanese living in the saudi Arabia
dr.pain is offline
post #4 of 23 Old 05-15-2018
So you're just a little too far away for me to stop by and check it out haha.
Yes please give us the codes...
dr.pain likes this.
yrktreg is offline
post #5 of 23 Old 05-16-2018 Thread Starter
Scan results
Please help
dr.pain is offline
post #6 of 23 Old 05-16-2018 Thread Starter
Scan
dr.pain is offline
post #7 of 23 Old 05-16-2018
Based on those scans, your camshaft position sensor needs replaced, your mass air meter is dead and needs replaced, and your secondary air pump isn't working and should be checked or replaced.
I'd start with those 3, and when repaired clear the codes or disconnect the ground wire in front of the driver seat for 10 minutes to clear the codes and then see how it runs.
Something is going on with your trans computer to as it's requesting a CEL.
dr.pain likes this.
yrktreg is offline
post #8 of 23 Old 05-16-2018
PS your supposed to fill the trans fluid with the car running and in park with the trans temp between 30 and 40C. Keep pumping the fluid in until it just starts to drip out of the fill hole.
dr.pain likes this.
yrktreg is offline
post #9 of 23 Old 05-16-2018 Thread Starter
Thank you guys
I really appreciate it
All of the sudden the started to develop sudden drop down while driving and the accelator doesn't worke
After this scan i stopped the car for a while then everything started to function normally
Attached to you video in the repair shop
Now ill do what u guys said
Ill pump in transmission oil
My question is last week i changed the gearbox oil ive added 6 litters but i think it wasn't enough
Its v6
So should i add more
The other thing is the repair mechanic advised me to change the PCV
He said it coused all of this
Please see the attached video
Thank you borthers
https://cloud.tapatalk.com/s/5afcc640...18_05_17_1.mp4
dr.pain is offline
post #10 of 23 Old 05-16-2018 Thread Starter
Yrktreg i really appreciate ur help bro
Thank u so much
May god bless you
Much love and respect
dr.pain is offline
