Malone Stage 2 with Delete or similar - Club Touareg Forums
post #1 of 17 Old 02-14-2019 Thread Starter
Good afternoon all from this newbie - I am actually an imposter, as we just purchased a 2013 Audi Q7 3.0 TDI with under 41k miles. However, it has Touareg guts.
I used to drive exclusively TDIs from the late 90's through 2008 and modified all of them with Rocketchips, big bore exhausts with muffler deletes, 2x oversize injectors, air intakes, VR6 clutches etc. Would like to modify the Q7 for similar gains (major) while realizing my modifications knowledge is arcane, and recognizing I won't be able to double the output of the Q7 for about a grand, as with the B4 Passat and 1st gen New Beetle TDIs.....looking to do as much as possible without going with an upgraded turbo, intercooler etc.
I am seriously considering Malone Stage 2 or similar and welcome any impressions or recommendations as to this or similar programming and the rationale. Also info from those with deletes - either Malone or others - benefits/drawbacks??
Would also appreciate info on any other performance mods in addition to these that won't break the bank, realizing how fast I want to go depends on how much I can spend.
Last, what is the impact of any performance mods on the extended exhaust/limited drivetrain warranty?
Many thanks,
Tom
Trae is offline
post #2 of 17 Old 02-14-2019
I have the Malone stage 2 with DPF/SCR/EGR deletes and RawTek DPF/SCR delete exhaust, and original TCM coding (from Joe/yrktreg). It is an absolute rocket from a standstill and at speed. Gobs of torque and still 10L/100km or better economy. The only drawback is if you have the EGR disabled, it could take a tad longer for the engine to warm up in really cold climates if you have a leisurely drive. The DPF/AdBlue system seems to be quite problem-prone (heater and pump failures, etc). By deleting the whole system you avoid that mess and gain a good amount more instant torque and shorter turbo spool time. You can do it in stages, of course. Get the TCM flash, then an ECU tune, the emissions deletes.
Naturally with any tune, you risk voiding the warranty if it's related to the failure. It is possible to "revert back to stock" with Malone, not sure about others.
Highly recommend the above mods.
- OEM air suspension retrofit
- OEM parking heater retrofit
chewblekka is online now
post #3 of 17 Old 02-15-2019 Thread Starter
*Bump*
Trae is offline
post #4 of 17 Old 02-15-2019
I wonder if Malone could code an increased idle based on Temp, or even a switch for upping the idle?
2016 Touareg 3.0 V6 TDI Lux
2018 Passat 2.0 TSI R-Line
RocketTech is offline
post #5 of 17 Old 02-15-2019
Originally Posted by Trae View Post
*Bump*
You can't bump your own thread less than 24 hours after a post lol.
Spoke with malone about having dynamic EGR like the ALH/BEW and he said its not currently possible, the EGR control in the V6 is rather complex.
post #6 of 17 Old 02-16-2019
I just had the entire EGR cooler assembly replaced under the powertrain warranty . 2013 TDI with 84,000 miles. Sigh...I miss Toyota reliability, but wouldn't head back to a 4Runner unless they offer a higher towing capacity and better fuel economy. I would miss 23-24 mpg that the TDI delivers, and strong road performance and handling characteristics.
As soon as I clock over the 100,000 miles, I will seriously consider getting a tune (likely APR) , with EGR delete and possible SCR (AdBlue) delete as well if that system fails. I am not certain I need the DPF deleted. I am only looking for reliability gains, with removal of the systems that are prove to reliability issues that cost a fortune to repair out of warranty. And also recovering some performance for towing a mid weight 6500 pound trailer.
ToolmanJohn is offline
post #7 of 17 Old 02-16-2019
Ah, Thanks. An idle-up sure would be handy; I guess it's not in the cards that way.
post #8 of 17 Old 02-22-2019
Does the EGR need to be Deleted physically with the Malone stage 2 or can it be left intact?
turbospool is offline
post #9 of 17 Old 02-23-2019
It doesnt need to be deleted. Im running the stage 2 delete tune with the adblue delete and straight downpipe. EGR is still intact for now.
04_sti is offline
post #10 of 17 Old 02-23-2019
Thanks, kinda what I thought , I just got this cel code for EGR temp sensor. Wondered why that would happen, if EGR is deleted?
DFE and adblue delete, Malone or APR tuning vw151 Engine, Transmission and Exhaust 92 2 Days Ago 05:20 AM
Malone Stage 1 rackhenry Engine, Transmission and Exhaust 3 09-01-2018 05:38 AM
MY 2013-16 delete tuning- JR Autotune or Malone yamajet Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 16 07-30-2018 09:42 AM
Malone Stage 2.0 2012 Touareg 3.0 TDi. jcart Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 32 01-26-2018 04:48 PM
