Jumping onto the Diesel Additive bandwagon - Club Touareg Forums
 5Likes
post #1 of 39 Old 02-12-2019 Thread Starter
Well, I decided to try these since so many of you swear how great additives are.
I just ordered a case of this stuff, and I will be using it in both my 2L and 3L TDIs.
The 2L has 249k kms on it, and has never had anything other than pump fuel put into it..... it's never given me any issues as far as gelling, fuel freezing, etc.
The 3L has 108k kms on it, but I've only had it for the last 8k, so I don't know if the previous owner used anything in the past.
I will attempt to report back on results if I notice any differences, etc.
trdltly likes this.
post #2 of 39 Old 02-12-2019
Interested to see if you notice any differences.
Here in Australia I try to use "BP Ultimate Diesel" which has some cleaning properties in our v8 TDI.
Haven't had any issues, but then nor have you.
Sent from my SM-T835 using Tapatalk
MarkLH69 is offline
post #3 of 39 Old 02-12-2019
In Europe, there's a minimum amount of cleaners that's mandatory with big brand fuel using more cleaner and even more in the high grade fuel.
Cleaners will improve an engine that's in poor condition but won't do anything if it's in good condition.
I use supermarket cheapest fuel but with a shot of Millers Power Ecomax every 1,000 miles - I can't tell any difference, though DIESEL POWER ECOMAX | Millers Oils - Advanced Lubricants, Oils and Fuel Additives
Black Grouse is online now
The Following User Says Thank You to Black Grouse For This Useful Post:
Togwotee (03-19-2019)
post #4 of 39 Old 02-12-2019
I am also looking into doing the same. I am looking for the cetane and lube increase. What made you decide on this product vs the 150 others? There are many that stand out and many that get great reviews. Just curious on your choice.
Being further north, you obviously need to worry about the colder temperatures.
Thanks.
trdltly is offline
post #5 of 39 Old 02-12-2019
Thanks.
As I understand it, any Cetane increase is minor and increasing it doesn't have the same effect as raising the octane on petrol/gasoline engines.
post #6 of 39 Old 02-12-2019
Not on power, but it definitely makes fuel burn better, which in turn lowers the amount of soot generated and also makes the engine run smoother. Diesel additives also usually help with fuel gelling, even though that generally shouldn't be a problem, but in the most extreme climates.
Gnits is offline
post #7 of 39 Old 02-12-2019
For the record, I am not swearing how great fuel additives are. I use a lubricity formula in the Touareg as an insurance policy against a fuel pump failure due to the HPFP and out area's low quality fuel.
For reference, I have a 2003 7.3L E-350, a 2004 Jetta wagon (1.9L), and a 2008 Chevy pickup. All are at 200,000 miles +/- 15,000. I had not added any sort of additive to them for more than a few thousand miles to see if it made a difference. This past summer, I had to replace the injectors on my Duramax due to excessive return flow. The cost was $3,200 plus two brutal days in the garage. Had the job been performed in a shop, I'm guessing it would have cost me twice that. None of the other vehicles has ever had any fuel system work performed on them. The injector failure was almost certainly a function of fuel quality, or lack thereof. However, if I had been adding Stanadyne Performance Formula to those three vehicles (and that's the one I would use if I used a general additive), I calculate that it would have cost me $7,000 - $8,000USD over those 600,000 miles. If your cars get better mileage, the cost goes way down.
There is supposedly a fuel economy increase when using additives, but I have not been able to discern one when I experimented with using them.
Full disclosure: Following the injector replacement, I started using the Stanadyne Lubricity Formula in my all of my diesel powered vehicles. I can't say if it is doing anything and I'm not sure it pays off economically even it if does do something, but it sort of makes me feel better.
buckwheat is offline
post #8 of 39 Old 02-12-2019 Thread Starter
Thanks.
Nothing specific... just lots of reading, and a reputable "well known" brand.
It was also a product that I could find and order online on this side of the border for a reasonable cost..... bringing stuff across the border adds all sorts of fees and such.
post #9 of 39 Old 02-12-2019
RobL's Avatar
I use it in the cold months as insurance. Like I stated before, got a batch of diesel during a cold snap last year that froze up the fuel filter. In a few weeks I'll stop using it and just use pump fuel. I dunno about needing extra lubricity or cetane boost. If the fuel pump grenades between now and 120,000 VW will buy a new one! Before I hit 120,000 I'll be in a full size (Expedition or Yukon) or trade for a very low mile 2016 Reef Blue (there is a Lux and an Exec on autotrader now, the Lux is a good deal but I kinda want an Exec) I just dont have the green light from the wife now, sigh....
2004 GMC Envoy "Rusty"(Sold), 2013 Jetta TDI (Buyback, 2017 MB GLC on order)
RobL is offline
post #10 of 39 Old 03-04-2019 Thread Starter
First update:
I am now on my first "treated" tanks in both the 2L & the 3L TDIs.
I will attempt to see if there's any MPG improvement or anything. In terms of startup\running, no noticeable difference.
It was -20dec C last night, and about -15dec C when I left for work in the 3L. It started as usual and as expected.
It's supposed to be brisk over the next 2-3 days, so I'm going to let my 2L sit and freeze "off the block heater" as a test to see if it fires up after sitting for a week in cold temps. (not that I wouldn't expect it to not do so - pre-treatment)
Stay tuned.
Question about gelling of diesel fuel in cold weather ckinge Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 24 12-18-2014 12:49 PM
Diesel fuel additive V10-downunder Australia & New Zealand 60 10-06-2011 11:04 PM
First Drive: VW TDI's Proving diesel isn't just for heavy... Big Joe General Maintenance & Repair 2 10-01-2004 04:18 PM
