How often, on average, does the V6 DPF regen? - Club Touareg Forums
post #1 of 13 Old 06-09-2017 Thread Starter
Touareg: 2009 V6 TDI
Question How often, on average, does the V6 DPF regen?
I can't find any info on this, and I there is no definite answer, but last Monday I was in the dealer for a forced regen, and this morning, the DPF symbol came up on the MFD.
I checked the blocks with the VCDS and block 104 shows the milage at 140 km. I hit the highway in S mode, and the DPF indicator went away, so I assume it did a regen.
I've put over 100,000km on the vehicle since I've had it, and i think I have only seen the DPF symbol twice, so I have no idea how often this happens. What is the average mileage people see between regens?
Mark J. Handy
2009 T-Rex TDI
VCDS
MJHandy is offline
post #2 of 13 Old 06-09-2017
182RG's Avatar
You should never see the DPF symbol, at all, unless you're not driving it enough or long enough to complete a cycle. Mine regens every 400 - 500 miles.
It's possible it's time for a new DPF.
182RG is offline
post #3 of 13 Old 06-09-2017 Thread Starter
How can i read the soot levels with VCDS?
Here's my readings from this morning, but i'm not sure how to read the values.
Mark J. Handy
2009 T-Rex TDI
VCDS
MJHandy is offline
post #4 of 13 Old 06-09-2017
182RG's Avatar
Check the Ross-Tech site. I believe it's under 'Advanced Measuring Blocks'.
182RG is offline
post #5 of 13 Old 06-11-2017
What $ did a regen set you back?
Mafuta
(2008 Touareg V6 TDI; 230,000km and going strong)
Mafuta is offline
post #6 of 13 Old 06-11-2017
A regen only happens if it doesn't burn off on its own from extended driving, so there is no answer. You saw the light because it needed to regen and when it tried, you didn't give it enough time. The light warns you to take a nice long trip on the highway before it is too late. Nothing to worry about unless it starts happening frequently or the light doesn't go out after taking a long drive.
Also, I wouldn't replace a DPF unless you have to, and then only after trying to clean it first.
m-fine is offline
post #7 of 13 Old 06-12-2017 Thread Starter
I had all the lights this morning, DPF, and Engine Fault workshop. I quickly read the codes, and there is one for the DPF pressure sensor. I cleared everything, restarted, no warning, drove an hour to work.
So i'll keep an eye on.
Mark J. Handy
2009 T-Rex TDI
VCDS
MJHandy is offline
post #8 of 13 Old 06-12-2017 Thread Starter
About $130ish CDN.
Mark J. Handy
2009 T-Rex TDI
VCDS
MJHandy is offline
post #9 of 13 Old 06-24-2017 Thread Starter
The issue is back, and I suspect the DPF pressure sensor, which I had replaced last year. I've since been able to figure out how to do a forced regen.
It may be time to think about gutting the system.
Mark J. Handy
2009 T-Rex TDI
VCDS
MJHandy is offline
post #10 of 13 Old 07-03-2017
Jimmyjames's Avatar
Touareg: 2005 V6 TDI
This makes perfect sense however you will technically be breaking the law by doing it. Saying all that you will have a better running, cleaner, more powerful, more fuel efficiant engine as a result. The general public are fleced into thinking DPF is a good thing, they simply aren't but the law is the law sadly.
Jimmyjames is offline
dpf
