Gear selector - Club Touareg Forums
post #1 of 29 Old 12-28-2017 Thread Starter
Touareg: 2004 R5
Gear selector
2004 R5 6 speed auto.
The PRDN display has gone out and the car is driving strangely, it's jerky.
The S and gear up and down functions don't work either.
I looked on the fuse cards and can't see anything that looks like it might be it.
The ESP light is on, pushing the button changes nothing.
Anyone know what it is?
Flash635 is offline
post #2 of 29 Old 12-28-2017
Moderator
hedditch's Avatar
I would be looking to do a VCDS scan. There is a good chance that it has nothing to do with the transmission, and may be it s missing a signal from a related component such as ABS, Stability Control (ESP) or similar. At least a scan will make the list smaller..
Stuart....
hedditch is offline
post #3 of 29 Old 12-28-2017 Thread Starter
Touareg: 2004 R5
Stuart....
Thanks Styuart.
You don't happen to know anyone in Brisbane who charges less than $150 per code do you?
Does the transmission range selector have a fuse?
Flash635 is offline
post #4 of 29 Old 12-28-2017 Thread Starter
Touareg: 2004 R5
It looks like it will probably be the range multifunction switch.
Can anyone tell me where i'ts located?
Flash635 is offline
post #5 of 29 Old 12-29-2017
Problems with the gear change can sometimes be down to the selection magnet on the underside of the sliding "blind" that surrounds the base of the gear lever falling off.
post #6 of 29 Old 12-29-2017 Thread Starter
Touareg: 2004 R5
I've heard about that; don't all the PRDN21 lights come on when that happens?
I don't think it explains the other symptoms.
Flash635 is offline
post #7 of 29 Old 12-30-2017
No. I mean anything might happen - but it's neither typical, not necessary with magnet problems.
Jerkiness is not a typical symptom for a magnet problem. However, inability of selecting S and/or not being able to shift manually up and down are.
Also, if any of the two magnets got lose, they could cause all kinds of weird problems with gear selection and shifting. Because they could randomly move around, and because there's an electronics board right below them, which they could short circuit, or generate implausible signals on.
Anyway, as already suggested, you should do a VCDS scan first. The reason for your problems could be literally anything, and without a proper scan, all you can do is guess blindly what's causing them.
Gnits is online now
post #8 of 29 Old 12-30-2017 Thread Starter
Touareg: 2004 R5
$150 per scan and last time I got them to do a scan they were wrong. Besides, they're not open for at least another week so it's guessing intelligently for the the time being.
I found a thread that showed in great detail how to get into the magnets, but the pictures were gone.
I'm downloading elsawin, only 18 hours to go!
A helpful member sent me a disc with elsawin on it when I first got here but I can't get it to set up.
So far in my searches I've seen reports that neither the magnets nor the multifunction gear switch faults show up on VCDS.
Flash635 is offline
post #9 of 29 Old 12-30-2017
Time to buy your own Ross-Tech cable?
post #10 of 29 Old 12-30-2017 Thread Starter
Touareg: 2004 R5
Yes, I think so. Would pay for itself quickly at these prices.
Heh, I saw somebody selling cables for $2 each! Yes, $2.00AUD. Had to buy 18 of them to get it at that price.
Flash635 is offline
