Gaging interest on ECU fix. I've had a lot of inquiries so... - Club Touareg Forums
post #1 of 131 Old 08-17-2018 Thread Starter
Second Vehicle: 2006 V8
It would go back to the pre-fix software. Would obviously fix the missing torque that has been neutered in the fixed version.
I'm trying to decide which is best:
1)Keep the fixed software revision number. So at first glance a dealer would think it has been fixed. This which would be detectable to a dealership if they looked into it hard enough though because it would change the calibration number.
2)Keep the pre-fix software number. So a dealership would see it as a stock pre-fixed ECU and this would prevent your car getting TD1 flagged as possibly being tuned and voiding your warranty.
I think #2, but want more opinions, or I could do either as an option.
Either way should you have to take say a #2 ecu into the dealer for warranty work, and they would reflash it back to fixed version I would only charge for shipping to anyone that has already purchased this from me.
Now the caveat the ecu's are a pain to get out (see PDF and security bolts).
Unless you can be without your car for a few days I would have to first send you a loaner. You install the loaner ECU, and send me your ECU back for programming. I then send you your original ECU back. You install your original ECU back in, and then probably I will have you ship it directly to the next person in line.
This is a little different than what we are doing with the TCM's obviously.
This is due to the immobilizer that is in the ECU's that is tied to your car.
Thoughts everyone??
yrktreg is offline
post #2 of 131 Old 08-17-2018 Thread Starter
ECU Removal...
yrktreg is offline
post #3 of 131 Old 08-19-2018 Thread Starter
OK Can't change the first post, so i'll add an option #3 here.
After spending yesterday doing a bunch more research this is what I can do
Basically it would be a pre-fix but would keep the fixed CVN, scanable software version, and the current flash counter would not be touched.
So in essence this would look to the motherland as nothing more than a fixed ECU on all accounts.
I would also like to add, that I have no idea if the pre-fix software will pass an emissions sniff test for those of you unfortunate enough to have a state that does that...
yrktreg is offline
post #4 of 131 Old 08-19-2018
Originally Posted by yrktreg View Post
Thank you sir, it was great working with you...
I'm working on a stock ECU solution BTW
Hi,
I didn't want to hijack your TCM thread so I'll bring the reply here. My main concern is denial of warranty. How could I explain a pre-fix ECU when the dealer did the fix themselves prior to selling the vehicle to me? Especially if they dug in and saw evidence of ECU tampering (tool marks, non OEM security bolts, whatever.)
Clearly there is risk to warranty when doing certain aftermarket work. I understand that. I'm familiar with but certainly not an expert on Magnuson-Moss so I don't really know how much protection it gives in this sort of situation.
I guess my initial thought is, if I'm risking the warranty may as well go for the gusto with a Malone stage II. Change my mind.
On edit: You posted your new option as I was composing this. That does change the calculus for me.
TomThumbs is offline
post #5 of 131 Old 08-19-2018 Thread Starter
Originally Posted by TomThumbs View Post
Hi,
You can purchase, or it would probably make more sense if I supplied the tamper proof bolts for re-installation.
I agree with you in that I am going to the extreme. Bigger turbo, and eliminating as much as I can to avoid future problems with it, Malone stage 30,000 tune, etc
Some people have asked about just going back to the old software to gain torque back.
I'm just trying to offer options and see what makes the most sense.
yrktreg is offline
post #6 of 131 Old 08-19-2018
Count me in..
2015 Touareg TDI
rackhenry is offline
post #7 of 131 Old 08-19-2018
To achieve this stealth, does one have to send his original ECU for flashing and wait for the turnaround or will the system that you use with the TCM swap work?
post #8 of 131 Old 08-19-2018
The Moderator!
Yeti's Avatar
Did the T3 loose that much with the fix? My '10 doesn't seem any different other than weird shifting on cold start. I don't think I lost much if anything as far as power or economy.
Yeti is offline
post #9 of 131 Old 08-19-2018
Built4Sin's Avatar
How is this not flagging a TD1 condition? I assumed its a flash counter on the chip itself, not a manual flash count update? Being that VW seems to be ok with tunes to an extent, and Audi flagging the VIN for being warranty blacklisted!
| Cayenne TT Sways |
Built4Sin is offline
post #10 of 131 Old 08-19-2018 Thread Starter
Originally Posted by rackhenry View Post
Count me in..
Got you at the top of the list sir!
yrktreg is offline
