DPF - Club Touareg Forums
post #1 of 7 Old 05-28-2018 Thread Starter
DPF
Hi all,
my tdi 2013 with 200.000 km has two lights on, DPF malfunctioning (that turn on/off by itself) and engine (pretty sure due to bad diesel here in Canada).
The DPF light says it won't run the vehicle in 700km, however is saying that since the last 2000km.... the malfunctioning alarm goes on/off so often that I believe it's only a false contact in the sensor itself.
Anyone has ever tried to replace it? Do you know where it is located and how much does it cost on average?
Thanks for any future comment.
Marco Ozzie is offline
post #2 of 7 Old 05-28-2018
DPF filters are a consumable thing. I've got 290,000km on a TDI Jetta and no change for the DPF in it. My T-reg is new (less than 7000km on it - so I'm in learning mode with it)
What is your driving style with the treg and how often and how long are your average drives?
Don't quote me but I've heard the DPF filter change is $1000+.
Does the system regen and how often? it needs to burn off the carbon and soot...
'16 Touareg 3.0 V6 TDI Execline | '12 Jetta 2.0 TDI Highline
~~I'd get better mileage if I would just drive slower...
gilty_one is offline
post #3 of 7 Old 05-28-2018
https://www.clubtouareg.com/forums/f4...ter-33160.html
I found another thread on DPF - just more info.
post #4 of 7 Old 05-29-2018
These lights are used to indicate a lot of different errors. You need to do a VCDS scan on the vehicle to retrieve the actual fault codes and details, which will pinpoint the problem with more accuracy. If you don't have access to VCDS, you can use an ODB2 reader, but that will return just generic codes, which - albeit - will yield more information than those two lights, but still be not as accurate as a VCDS scan.
You can't know that. The lights going on and off can have several reasons. And even if it was just a sensor issue, that could also very well damage your vehicle "permanently" (ie result in the need to repair and replacement of other, affected components).
The DPF is part if the exhaust system, so it is located under the belly of your car, usually near the transfer box, under the front seat row.
Exact prices may vary by market and model, but generally expect it to cost around 2000-3000 Euro when bought new and from a VW dealership. There are also methods to clean the DPF (which usually do not work well, but might give you a few ten thousand miles more), and to replace its innards, which however might not be legal in all jurisdictions and might lead to the vehicle failing the MOT / DMV inspection, if noticed.
Gnits is offline
post #5 of 7 Old 05-29-2018
As per Gnits above you need to get the vehicle properly scanned ASAP for faults in order to determine exactly what the issue or issues are.
Post the output on here and people may be able to help you better.
post #6 of 7 Old 06-04-2018 Thread Starter
thank you for the answers!
I noticed the DPF alarm turns usually on while driving at highway speed, 120 km/h-75mph.
When driving in the city automatically goes off...
Now I am refueling with only diesel Vpower, hopefully it might help to clean up injectors and converter
post #7 of 7 Old 06-04-2018
tdimark69's Avatar
The more old lady you drive the more your dpf will fill up...these diesels love a load and a good workout to burn up the soot and run it threw the paces.
2012 Highline Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap - EGR Cooler Delete
tdimark69 is offline
