CP3 HPFP Failures - Club Touareg Forums
  • 1 Post By JimJ
post #1 of 5 Old 05-29-2017 Thread Starter
Question CP3 HPFP Failures
As a follow on from the https://www.clubtouareg.com/forums/f67/2008-tdi-warning-light-then-silence-259834.html thread
the tech claimed that all pumps can fail and the CP3 was not any different to the CP4 in that regard.
OK, so who has had a CP3 pump fail and the reason?
alfissimo likes this.
JimJ is offline
post #2 of 5 Old 05-29-2017
Moderator
hedditch's Avatar
During my research into the failure risks of the CP4 series, I found a number of Diesel Service shops in the USA who were swapping out CP4 pumps and replacing them with CP3's. All the first series T2's using BKS engines run CP3 pumps. It will be interesting to see what responses you get.
Stuart...
hedditch is offline
post #3 of 5 Old 05-29-2017
alfissimo's Avatar
I am curios too. Should have made a poll.
I have a CP4 in mine, 105K miles so far. Honestly not sure what makes a CP3 better than a CP4.
10' TDI
alfissimo is offline
post #4 of 5 Old 05-30-2017
Second Vehicle: 2009 V6 TDI
Different designs, 2 pistons in the cp4 vs 3 in the cp3. When my Duramax CP3 went out, it did so without any catastrophic damage or issues, just pulled the old and put the new in. By the way the truck was still running and pulling fine a low rpms, it wasn't till higher rpms 2500 and above that the issues showed up. Found that it was only putting out half the pressure to the rails. Drove around with a OBDii code reader to reset the limp mode for 6 months, before working on it. But that was in LB7 duramax
Marbles is offline
post #5 of 5 Old 05-30-2017
alfissimo's Avatar
I suppose less heat with 3 pistons. That could make a difference. 2 is working a lot harder.
10' TDI
