Cold Start Help - Club Touareg Forums
post #1 of 7 Old 09-25-2017 Thread Starter
Cold Start Help
Hi. Hoping for some advice or guidance. On cold starting my engine spins but does not start for quite a while and when it does there is a large cloud of white smoke. It doesn't quite get to the stage when then battery flattens, but I get the feeling that it's not far off. When the car is running the battery guage tells me that battery is charging and I obviously wait until the glow plug light goes out before turning the key. However, when restarting the car after the initial start it fires after about 2 to 3 turns. There are no issues with performance or fuel consumption. I don't know how old the battery is...it may even be the original. If this is indicative of a failing battery then I'll get a new one before the winter sets in. But if it is something more sinister then I'll need to get it looked at soonest. Thanks for reading. 2008 V6 Diesel Altitude.
lovie1961 is offline
post #2 of 7 Old 09-25-2017
I doubt it's your battery as white smoke could be unburnt diesel.
A long time turning over on the first start as the weather is getting colder suggests it may be glow plugs.
Put the car on VCDS - that is always the starting point.
Join the UK site - www.mytreg.com - there may be someone near you who can do a scan.
lovie1961 (09-27-2017)
post #3 of 7 Old 09-26-2017
Scubacruiser's Avatar
x2 on glow plugs. But check your battery too.
Scubacruiser is offline
The Following User Says Thank You to Scubacruiser For This Useful Post:
post #4 of 7 Old 01-25-2018
Mine is exactly the same as you described,. I've got a set of. Glow plugs waiting to go in
However, my battery is around 11.5v when I first turn ignition on, which I think. Is issue
I did an overnight charge, the next day it was just over 12v and started instantly
m.r.davies is offline
post #5 of 7 Old 01-27-2018
What is your battery level reading?
post #6 of 7 Old 01-29-2018
Typically white smoke would indicate unburned fuel on a cold start engine. Could be glow plugs or battery that needs replacing. As suggested get codes read, Id also put a battery charger on it and fully charge then try it again. If it fires right up Id replace battery, how old is the battery now?
j
New to us 2012 Touareg TDi
Malone and Rawtek gear.
2015 VW Jetta TDi CL Sport MT (Sold Back to VW
Old Body style 7.3 Powerstrokes
Looking and learning about Touaregs
jcart is offline
post #7 of 7 Old 01-30-2018
4ePikanini's Avatar
Touareg: 2005 R5 TDI
General consensus is that the starter is not up the task at around 20 celsius when glowplugs are not used. Any colder and the glowplugs are used so the engine catches easy.
There is a revised 2.2kw starter you can buy from rexbo.eu.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is online now
