BWF Replacerment - Club Touareg Forums
post #1 of 14 Old 08-18-2018 Thread Starter
Touareg: 2008 V10 TDI
Second Vehicle: 2010 V6 TDI
BWF Replacerment
Does anyone know if you can use older AYH, BKW,BLE or ALS to replace 2008 BWF.
Glenn.Ca is offline
post #2 of 14 Old 08-18-2018
The engine blocks are more than likely the same, but anything that bolts to it is going to be different, so you'll have a lot of transferring and head scratching to do
Dpkhym is offline
post #3 of 14 Old 08-18-2018 Thread Starter
I知 aware of transferring the parts and accessories but am Leary of the difference in fuel filter location ( mine is on the fender not in engine valley on top of alternator). Will the auto transmission bolt up ok? Is the block the same for fitment of EGR cooler?
Glenn.Ca is offline
post #4 of 14 Old 08-18-2018
A BLE engine would be a direct replacement an AYH would not be due to fuel end EGR as you have mentioned.
The exhaust system would different but every thing else would be the same.
regards
Drag
dragline1570 is offline
post #5 of 14 Old 08-18-2018 Thread Starter
Thanks for the info, I知 aware of camshaft difference in some but good to hear I can use a BLE as a BWF is so far hard to find.
Glenn.Ca is offline
post #6 of 14 Old 08-18-2018
The cams in all V10 engines are identical
Regards
Drag
post #7 of 14 Old 08-18-2018
Second Vehicle: Old heap
Regards
Drag
Hey Drag even the R50?
Vaughan Manders is offline
post #8 of 14 Old 08-19-2018
Even the R50 Vaughan
Regards
Drag
post #9 of 14 Old 08-19-2018 Thread Starter
The parts catalog shows BLE,BWF and CBWA all use 07Z 109 101E and F
BKW uses 07Z 109 101J and K
Glenn.Ca is offline
post #10 of 14 Old 08-20-2018
Yes you are correct the part numbers are different but having put the following on a cam doctor machine - a genuine AYH, an aftermarket AYH, a genuine BLE, a genuine R50 cam, and a colt cam the only difference was the colt cam which changes from the std solid cam lobe profile to a hydraulic lobe profile.
Regards
Drag
