Brake pedal firms overnight - Club Touareg Forums
post #1 of 5 Old 07-18-2018 Thread Starter
seafarer28's Avatar
Just curious to know why my brake pedal is very hard (does not compress at all) before first start up each morning, within a second or so after start it goes back to the normal feel, subsequent starts during the day do not suffer from this anomoly .
This is the second touareg that I have/had that has developed this issue.
Anything to worry about?
TonyB
P.S. I know I have exposed myself to Nooby's quirky sense of humour with this post
MY08 V6TDi, Campanella White
seafarer28 is offline
post #2 of 5 Old 07-19-2018
Moderator
hedditch's Avatar
Hi Tony,
Mine is exactly the same, and has always been like that. I put it down to a less than perfect vacuum chech valve on the booster.
Stuart...
hedditch is offline
post #3 of 5 Old 07-19-2018 Thread Starter
seafarer28's Avatar
Thanks Stuart.
Happy to know that I'm not the only one with that irregularity, I did suspect something like that may be causing it.
Both of my cars seem to have acquired that issue as they aged.
TonyB
post #4 of 5 Old 07-20-2018
Chris Anderson's Avatar
Touareg: 2005 R5 TDI
My 2005 R5 has the same "feature".
Sent from my SM-G960F using Tapatalk
Chris Anderson is offline
post #5 of 5 Old 08-13-2018
Second Vehicle: 2006 V8
Also chasing this down on our 2006
Just purchased a pair of aftermarket check valves and will be replacing them factory ones with working ones...
It's definitely a vacuum leak somewhere in the system. Could be faulty check valves, or these nice plastic hoses tend to crack where they are formed in place at the fittings.
I've inspected/ replaced all of the faulty lines so now it's check valve time...
yrktreg is offline
