13 V6 TDI diesel exhaust smell. - Page 2 - Club Touareg Forums
post #11 of 14 Old 3 Weeks Ago
Have a look in the engine bay either side of the engine on the guards at about exhaust manifold height and look for a black tar like substance spread about.
If you see any it will be blown injector seals.
Quite common on T3 diesel engines.
Regards
Drag
Originally Posted by EdReid View Post
Ok, this for sure am exhaust smell not a diesel fuel smell. So I’ll start looking around I suppose. Cause this happens quickly while stopped I don’t think it’s from the tail pipe I think I have some issue under the hood. Thanks for the replies!
dragline1570 is offline
post #12 of 14 Old 3 Weeks Ago
Hi,
Below both outer rear seats, there are two hatches that give acces to the fuel tank pumps and piping. Worth checking if they sit properly and also the condition of the quick coupling connectors of the fuel pipes.
Also have a look at the fuel filter housing, it is very close to the hvac air intake. If there is a leak there it is very likely that the smell will be noticeable in the cabin.
I hope it helps.
Gabs14Trg is offline
post #13 of 14 Old 2 Weeks Ago
My 2012 Touareg TDI was just in the shop for 2 weeks for replacement of a split connector pipe that connects the turbo and the EGR cooler. It was an extended warranty repair as a result of the "fix".
I noticed that my cabin air intake was drawing in leaking exhaust coming from the engine compartment when stopped or at very low speeds. I used to turn off cabin air fan when not moving, even then I could smell a slight exhaust odor. Definitely get it fixed, raw diesel exhaust is no good for your lungs.
I bought the Treg with this issue unknowingly only a thousand miles post-fix. Luckily the repair was covered. Since it has been back the exhaust smell is completely gone.
If the dealership tries to ding you for a diagnostic fee call the extended warranty center and get them to approve it. It is a known problem.
randy14b is offline
post #14 of 14 Old 4 Days Ago
I purchased a 2013 that was "fixed" and had similar concerns.... I had an exhaust leak at the turbo to the downpipe. I've since replaced the downpipe with a rawtek pipe, and that problem was fixed. I also noticed that the #1 and #4 cylinders were both missing the copper gasket on the injectors, so I replaced those too, after my #1 injector blew out on me!
so check for soot between the turbo and exhaust, and also look at the little holes on the sides of the cylinder heads to see if they're seeping black death.
Ryan Mills is offline
Exhaust Smell alfissimo Engine, Transmission and Exhaust 7 10-05-2018 08:27 AM
3.0 TDI CATA swap into midsize truck rose351 Engine, Transmission and Exhaust 17 08-31-2015 02:24 PM
Question about gelling of diesel fuel in cold weather ckinge Diesel (TDI) Engines | R5, V6, V8, V10, R50 TDI engines 24 12-18-2014 12:49 PM
Exhaust Brake for 2010 TDI? GolfStream Off-Roading & Towing 1 03-18-2011 06:17 PM
Porsche Cayenne 3.0 diesel V's Touareg V6 TDI Flipper Dog General Maintenance & Repair 9 03-30-2009 03:31 PM
