What is Coolant Pump 2, MIL ON - Club Touareg Forums
post #1 of 10 Old 03-05-2017 Thread Starter
The MIL came on yesterday, VCDS Scan below saying Coolant Pump 2 Open Circuit, any insight would be appreciated.
Cold here this morning, single digits and i did notice that car warmed up very slowly.
Sunday,05,March,2017,09:58:22:31878
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
Ross-Tech: Home
VIN: WVGFF9BP2BD004954 License Plate:
Mileage: 143715km-89300mi Repair Order:
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
69 6C 6D 72
VIN: WVGFF9BP2BD004954 Mileage: 143715km-89300miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CGRA) Labels: 03H-907-309-V1.clb
Part No SW: 03H 906 023 B HW: 03H 907 309
Component: 3,6 FSI ULEV2 H15 8643
Revision: M7H15---
Coding: 002A0012433600000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM36FSI01103H906023B 002005
ROD: EV_ECM36FSI01103H906023B.rod
VCID: 21437A1130B56C4AE6-8074
2 Faults Found:
12348 - Coolant Pump 2
P261A 00 [175] - Open circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 143597 km
Date: 2017.03.03
Time: 20:26:45
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 80 C
Intake air temperature: 9 C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 12.722 V
Unlearning counter according OBD: 40
Relative load value: 67.95 %
2947 - Oxygen (Lambda) Sensor Signal B2 S2
P2272 00 [096] - too Lean
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 143128 km
Date: 2017.02.22
Time: 11:52:43
Engine speed: 1487.00 /min
Normed load value: 47.1 %
Vehicle speed: 81 km/h
Coolant temperature: 60 C
Intake air temperature: 15 C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.442 V
Unlearning counter according OBD: 10
Oxygen sensor bank 1 sensor 2: response time: 0.00 s
Oxygen sensor aging test bank 1 after catalytic converter: 1.15 s
Rear cat conv temp main cat conv model value: 845.10 C
Oxygen sensor bank 2 sensor 2: response time filtered: 0.03 s
Oxygen sensor aging test bank 2 after catalytic converter: 1.50 s
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 A HW: 0C8 927 750 A
Component: AL1000 AISIN 001 1870
Serial number:
Coding: 001368
Shop #: WSC 55015 001 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001.rod
VCID: 2A519D3D4D83AF12B7-807E
No fault code found.
Address 03: ABS Brakes (J104) Labels: 7P0-907-379.clb
Part No SW: 7P0 907 379 H HW: 7P0 907 379 A
Component: MK25A H36 0417
Revision: -------- Serial number: 404910010EC010
Coding: 5B7613C349242557DAFDC89892D6A4407700
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 4281D59DD5F357529F-8016
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 AK
Component: BCM2 2.0 H24 0217
Revision: 00002001
Coding: 09860000000000000000
VCID: 72E1455DADD3A7D2CF-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Serial number: 0810000104720008
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000102100015
Address 08: Auto HVAC (J255) Labels: 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0613
Coding: 4606200A80
ASAM Dataset: EV_AirCondiFront 004001
ROD: EV_AirCondiFront_VW52.rod
VCID: 79F37271F8A5D48A8E-802C
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000946193
Coding: 26001012973C5D010020180300005D0C431C66088201026100 0000020000
VCID: 31638A516855DCCA76-8064
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110211 31 0020
Serial number: 90243400110219022253
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10126203
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000001002110133
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R08PE06
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag02D H05 0023
Revision: -------- Serial number: 003JX001ME5B
Coding: 000000000000000000000000000000003244
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 4085DF95DBFF454289-8014
Seat occupied recognition:
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R10A01020R6
Crash sensor for side airbag: driver side:
Serial number: 3575LRB40590DGES4HGX
Crash sensor for side airbag: front passenger side:
Serial number: 3585LRB40590DGES71OT
Crash sensor for side airbag: rear: driver side:
Serial number: 3515RRB40670BTBGBO3T
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525RRB405R0BTBGJPFR
Crash sensor for front airbag: driver side:
Serial number: 3555NRB405H0DD2AAHIG
Crash sensor for front airbag: front passenger side:
Serial number: 3565NRB405H0DD2ACHPQ
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 A HW: 7P6 953 507
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KB90009V
Coding: 000015
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0059373
Address 17: Instruments (J285) Labels: 7P6-920-xxx-17.clb
Part No SW: 7P6 920 980 M HW: 7P6 920 980 M
Component: Kombi H12 0239
Revision: 10240061 Serial number: 658030211593052
Coding: 8B7732022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 4689C98DF9DB6B72B3-8012
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000099718
Coding: 0021032600
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 3875B775832F0D8231-806C
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650576514
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002326850
Coding: 0058130000004001000001010101202020202121202020
VCID: 346D83459747E9E21D-8060
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000112736007
Coding: 011D07205E00453005080000
VCID: 3C7DAB65BF1721A2D5-8068
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0142228160
Coding: 0186123A28B9509480B0062021000000000000000000000000 0000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 019111443
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H07 0006
Serial number: WOO1127265+
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H07 0006
Serial number: WOO11317973
Coding: 191100
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000113259001
VCID: 3B7FA879BA19269ADC-806E
Address 53: Parking Brake (J540-) Labels: 7P0-907-801.clb
Part No SW: 7P0 907 801 E HW: 7P0 907 801 E
Component: EPB H51 1100
Revision: 00000000 Serial number: A11203000DD
Coding: 01040000
ASAM Dataset: EV_ParkbA7 000006
ROD: EV_ParkbA7.rod
VCID: 356BBE41943DF0EA2A-8060
Slave 3:
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: --------------
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CFD6B65F797E1A295-8028
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0001
Coding: 130000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0001
Coding: 130000
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471BZ0B7559054
Coding: 020007020100000001
VCID: 5DBB06E1444D08AA82-8008
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 HW: 7P6 035 664
Component: H-BN-NA H43 0170
Revision: -------- Serial number: 445BQ0B7511146
Coding: 010200050040E1EE41022B0C00000003F0080101
VCID: 75EB7E41DCBDB0EAEA-8020
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H24 0045
Serial number: VWZ8Z9L29004TJ
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 62: Door, Rear Left (J38 Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000113189504
Coding: 011C07200000253005080000
VCID: 3A71AD7DB5231F92C7-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000023031
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3F87DC69A6013ABAF0-806A
Address 69: Trailer (J345) Labels: None
Part No SW: 7P0 907 383 B HW: 7P0 907 383 B
Component: Anhaenger H07 0100
Revision: 5A001001 Serial number: 00000142347902
Coding: 020D000000000000
VCID: 3777B449863102FA38-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H04000 Serial number: 525 PA8J110050
Coding: 0110001
VCID: 3777B449463102FA38-8062
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 033100313
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000113043700
End-------------------------(Elapsed Time: 04:43)--------------------------
VWBob is offline
post #2 of 10 Old 03-06-2017 Thread Starter
I have figured out the fault code above is a non working Auxiliary Water Pump 059121012B
Searched here and on the web but not exactly sure of the location, it is in a bracket that is probably attached on the side of the engine somewhere and will take a look when I get home.
If anybody has replaced this part, either at shop or themselves any additional info would be appreciated.
VWBob is offline
post #3 of 10 Old 12-06-2018
Touareg: 2013 V6 FSI
I know this post is old but I think I have the same problem. Where did you find the pump on the engine?
kickboxin is offline
post #4 of 10 Old 12-09-2018
G6mdxvct's Avatar
My VR6 (T1) has an electronic re-circulation pump V55 as part of the coolant system. The pump works when engine shut off and their is no driving airflow.
G6mdxvct is offline
post #5 of 10 Old 12-09-2018
G6mdxvct's Avatar
Think it is located behind the alternator in front of the oil cooler. Should have two connections for water and one electrical connector.
G6mdxvct is offline
post #6 of 10 Old 12-09-2018
G6mdxvct's Avatar
It gets pretty cold here in Nebraska and the fastest way to warm up the car is drive it. Sitting at idle on a cold day takes quite some time for temp to even hit 100. Have to drive 15 or so minutes to get to 200 when temp below 20F
G6mdxvct is offline
post #7 of 10 Old 02-11-2019
I found and replaced it. It was at the back of the ending bolted on. If you follow the hoses from coolant reservoir down, it is about a 12 inches down in the mess off coolant hoses. I replaced in but the error message stays.
post #8 of 10 Old 03-03-2019
Is your Touareg the 4.2 V8?
NavyV8Touareg is offline
post #9 of 10 Old 03-04-2019 Thread Starter
Unfortunately on our the connector was fried, pump must have shorted out and fried the connector. I had bought the part and ended up having dealer put in, with a new connector and labor it ran almost $300 but working good since then.
VWBob is offline
post #10 of 10 Old 03-04-2019 Thread Starter
We have had some cold weather here this winter and our VR6 takes forever to warm up too, if it was a bad thermostat the ECU would throw a code because there is a parameter for how long it should take for engine to get to operating temp so maybe the sensor that gives single to gauge on dash is different but still can take way longer to get to 200 than it seems it should
VWBob is offline
