Touareg stalls after fueling....??? - Club Touareg Forums
post #1 of 6 Old 01-14-2015 Thread Starter
Touareg: 2006 V6
This issue has been happening for a few months now and is driving me insane! Mechanic can't seem to diagnose. After getting gas (regardless of type or amount) when I go to start the engine, it won't fire up unless I put her in neutral, hold down on the break and press all the way down on the gas pedal. The check engine light is on and diagnostic test showed that bank 1 and bank 2 O2 sensors were bad. The Touareg then failed emissions for the bank 2 sensor only, passed all other tests. Are all these issues related and what is causing this? The diagnostic only popped 2 codes, the above mentioned.
Thanks for any help you can give!!
AshleighJ is offline
post #2 of 6 Old 01-14-2015 Thread Starter
Touareg: 2006 V6
Sorry, forgot to share that I have a 2006 3.2
post #3 of 6 Old 01-14-2015
jsrmonster's Avatar
Check fault codes relating to vacuum leak. There is a electrical vacuum pump, and a bunch of plastic piping that can crack at the joints and leak from the pump to the intake, to the power brake booster. You can find the leaks and replace piping or wrap with electrical tape and cover that with duct tape.
Jeff
jsrmonster is offline
post #4 of 6 Old 01-14-2015 Thread Starter
Touareg: 2006 V6
Thanks Jeff! The fault code is 0491, but I'm not sure the specifics of that code. Where is the piping your speaking of located? Is it by the fuel pumps under the passenger seat?
post #5 of 6 Old 01-14-2015
jsrmonster's Avatar
The vacuum piping is under hood on passenger side upper fender well. its about 1/2" dia and goes from the front vacuum pump and tees to intake manifold, and goes into the plenum above the fire wall. There are other smaller vacuum lines that control evap, and also intake runner flap/solenoid.
Jeff
post #6 of 6 Old 01-14-2015 Thread Starter
Touareg: 2006 V6
I will look into this! Thank you!
