Stalls after 10-15 Minutes of Driving - Club Touareg Forums
post #1 of 6 Old 07-13-2014 Thread Starter
Hello all ...
Been seeing a problem where my 2004 V8 Touareg (82k miles) dies after about 15 minutes of driving. It happens while idling and while under load. The first time I was stranded, had the Reg towed to the local Vegas VW dealer. They diagnosed it as low fuel pressure and therefore it needed new fuel pumps. So, I took it home and replaced both fuel pumps and the fuel filter with OEM parts (had a Carmax tech who had done the job before assist). Starts fine and idles for 15-20 minutes no problem. When I drive it, it dies after about 10-15 minutes - same as before the fuel pump change. Car will crank, but not start. If it sits for 30-60 minutes, it will start and run for another 10-15 minutes and the cycle repeats. Seems like something is overheating. No check engine light at the moment. What other items should I consider?
Thanks all!
vegas-reg is offline
post #2 of 6 Old 07-20-2014
had same issue. thought it was my cam position sensor. replaced one new other used, still had issues. continued to research and found out about cankshaft position sensor. removed and found small pieces of metal on sensor. cleaned sensor and re-installed. reg now starts fine and stays on. also my check engine light never came on but a code was being stored. po322. check it next time it stalls.
TouMan is offline
post #3 of 6 Old 07-22-2014
update. took treg out for long drive was out for about 20 minutes all mainly 60mph. when it turned off i was coasting to a stop. 30 minutes later started right up. being at work i knew it was going to stall on me on my way home so i planned at stopping at a oriellys so it could cool down while i shopped for parts. made it to orieelys witch was 21 minutes of driving didn't die. stayed in parking lot for another ten minutes didn't die. oriellys didnt have part, so going to be looking at flebay. left oriellys and made it home. going to completely remove sensor, test and inspect. will keep post updated. also my treg only has 60k, living on Oahu.
TouMan is offline
post #4 of 6 Old 07-24-2014
so completely removed sensor. cleaned inspected and re-installed. reg stay on for about 45 minutes, went for a quick drive in nieghborhood. car stalled. waited 30 minutes drove it home. sensor ordered. also will be replacing spark plugs and valve cover gaskets for a small oil leak.
TouMan is offline
post #5 of 6 Old 07-26-2014
received crank sensor. replaced, routed like stock. fixed other items i broke (intake box came apart) started reg. started right up no issues. went for a drive, let it heat up. drove it like i stole it came home turned it off, started right back up no issues. been driving it all night making random errands running strong. so solution - replace crank posistion sensor, or engine speed sensor. (same)
TouMan is offline
post #6 of 6 Old 09-17-2014
G6mdxvct's Avatar
Had a similar problem with a camshaft sensor. When the engine got hot and the sensor got hot, the sensor quit sending a signal to the ECM. Let the car sit awhile and would restart fine. VW could never figure it out. If the ECM does not get a signal from the speed sensor the car will shut off if running or not start at all if not running. If the ECM does not get a signal from the camshaft sensors car will start but will take longer to crank sometimes much longer with the ECM using the speed sensor alone to determine which cylinder is at TDC based on crankshaft position. Normally all three sensors send a signal to ECM which allows for a quick start.
G6mdxvct is offline
crankshaft positon sensor , ecm , fuel pump , touareg
