Rough running at highway speed - Club Touareg Forums
post #1 of 11 Old 01-25-2015 Thread Starter
So I just had an O2 sensor and a vacuum hose replaced and it didn't seem to fix this problem. It will start fine. Run fine in town for extended periods of time as well. However, I'm currently on a road trip and when it get's warm it feels like it just isn't getting enough air and just shakes. If I put my foot into it and kick it down into 5th gear at high RPM's, it's fine but, it doesn't feel like there is much power there. At least not as much as there would be if it was running right. Stopped for 5 minutes at a rest stop, looked under the hood, smacked it around a little, got back in and went back down the road and it was fine until today and another 30 mile trip down the road at high speed (80ish mph) and it started doing it again. Another 10 minute rest stop and it was fine. Went back the same 30 miles at a slower speed and nothing. I'm so confused! Any suggestions? The check engine light is of course on but, I haven't had a chance to see what the codes are.
JazzmanWA is offline
post #2 of 11 Old 01-25-2015
Scan it
lgibson is offline
post #3 of 11 Old 02-12-2015 Thread Starter
OK, here goes...
17763 - Cylinder 1 ignition circuit
16684 - Random/multiple cylinder misfire detected
16685, 16686, 16687, 16688, 16689, 16690 Misfire in each of the 6 cylinders.
17522 O2 sensor (which was just replaced)
16814 Catalyst system bank 2
16804 Catalyst system bank 1
Any help?
Feels like every once in awhile someone is using a jake brake on my treg.
post #4 of 11 Old 02-13-2015
G6mdxvct's Avatar
Originally Posted by JazzmanWA View Post
OK, here goes...
Any help?
Well not sure fire but would replace coils and plugs.
G6mdxvct is offline
post #5 of 11 Old 02-13-2015 Thread Starter
Coils were replaced last summer and plugs were replaced in the fall. Any other ideas?
post #6 of 11 Old 02-14-2015
What type of motor and how many km's?
Pcv valve?
benb2376 is offline
post #7 of 11 Old 02-14-2015
G6mdxvct's Avatar
Could be fuel air problem. Ever clean your throttle body? Kind of odd after a cool down car is temporarily ok. Maybe camshaft sensor or sensors giving incorrect position signal to ECU when they get hot? This might account for misfire codes. You could pull them and clean them, same for throttle body. Could also be PVC. Only other thing I can think of is a problem with the injectors. Depending on the quality of the direct ignition coils some have poor efficacy and can go bad. There are crap ones out there.
G6mdxvct is offline
post #8 of 11 Old 02-18-2015
Hi All,
I have the same problem and I also realize that is when engine gets hot, first I thought that was because it had a manifold linkedarm broken but I replace it and didn't fix it. I'm going to scan it and later i will share my codes with you.
tonysol is offline
post #9 of 11 Old 02-22-2015
codes
Originally Posted by tonysol View Post
Hi All,
P0171-----BANK 1 SYSTEM TOO LEAN
P0174-----BANK 2 SYSTEM TOO LEAN
P1009-----NO DTC DEFINITION
P0101-----MASS OR VOLUME AIR FLOW "A" CIRCUIT
P010B-----MASS OR VOLUME AIR FLOW "B" CIRCUIT
P2234-----OXYGEN SENSOR SIGNAL CIRCUIT SHORTED TO HEATER
Any help???
tonysol is offline
post #10 of 11 Old 02-23-2015
4ePikanini's Avatar
Touareg: 2005 R5 TDI
get a VCDS scan.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
