Oil temp gauge? - Club Touareg Forums
post #1 of 9 Old 06-22-2012 Thread Starter
atxtouareg's Avatar
Oil temp gauge?
I am used to having trans temp gauges. Why do we have an oil temp gauge? I cant see the use for it...I could see more use out of an oil pressure gauge. I just changed the oil and now that outside temps are 100+, the oil temp is around 200*
Whats the normal operating range? I'm used to seeing it right around 175-180*
TIA
2005 Black VW Touareg V8 - RNS2 Nav/JL Audio - Air Suspension - 19" VW wheels - Morimoto 5k Lows and 4300K Fogs
atxtouareg is offline
post #2 of 9 Old 07-12-2012
dvmis's Avatar
Send a message via Skype™ to dvmis
Same here. Typically stacked at 90 deg C but in summer goes to 95-100 deg C.
dvmis is offline
post #3 of 9 Old 11-24-2015
Should the oil temp gauge move at all when going up amountain I notice it normally sits at 180-200 but going up hill for about 20 miles it moves up to about 220
Ron m is offline
post #4 of 9 Old 11-24-2015
Moderator
hedditch's Avatar
Looks "normal " to me.
hedditch is offline
post #5 of 9 Old 11-24-2015
Learner
Singh's Avatar
Second Vehicle: 2015 V8 TDI
Oil temp around 90-110 C is normal, will move with speed/ load etc.
Water should be at 90 C all the time
Singh is offline
post #6 of 9 Old 11-24-2015
MtnPass's Avatar
We live near a steep mountain area. We don't work the Touareg too hard until the oil temp is normal zone.
I would rather have a transmission temperature gauge for towing...
-Bill-
'08 VW Touareg V8 Lux Tow Hitch
'09 VW Touareg TDI Lux Tow Hitch
'11 Silverado Duramax Diesel SB Crew LTZ
MtnPass is offline
post #7 of 9 Old 11-24-2015
4ePikanini's Avatar
Touareg: 2005 R5 TDI
I have seen up to 120 celsius oil temp when towing with my R5.
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
post #8 of 9 Old 11-25-2015
Odessa's Avatar
Touareg: 2009 V6 TDI
Yep as said above and most important .... depends on load and time ie how long the work was done for.
I have also seen almost up to 120c in soft / hard sustained sand driving for around 50 - 100 kms and carrying around 300kgs on board as well as 2 people.
Interesting to note oil temp comes down real quick after a short stop.
And the coolant temp always was on 90c
Now i have a winch installed so for some reason it creeps up to around 108c max once normally warmed up. I still dont know how this happens considering the cooling system works through osmosis .... there is marginal blocking of the radiators .... but its not your usual sized winch
Odessa is offline
post #9 of 9 Old 11-25-2015
Thanks for all your answers they helped a lot I was getting worried alittle seeing the gauge move on me I'm a new owner and bought used and dropped a lot of money fixing some things and did not want to think something else was happening I love this car
Ron m is offline
V10: Exhaust Workshop - low oil temp, low water temp 4xMotionTDI General Maintenance & Repair 34 12-04-2018 09:19 AM
GETTING NEW GAUGE CLUSTER TODAY-OIL TEMP GAUGE BROKEN AB328 General Maintenance & Repair 4 06-12-2012 12:03 PM
Oil gauge's issue!! MadFacial General Maintenance & Repair 5 04-01-2011 01:04 PM
Why Oil Temp vs Pressure Gauge strokethis2 General Maintenance & Repair 15 08-16-2010 07:46 PM
Oil Temp v Water Temp dunc_b General Maintenance & Repair 9 01-22-2008 03:15 PM
