Noise only when turning right - Club Touareg Forums
post #1 of 8 Old 10-29-2012 Thread Starter
04vwtouaregv8's Avatar
My 04 touareg started making a humming/grinding noise when I am turning right, the harder you turn the louder the noise, seems to be worse around 60km/h but you can still hear it around 100km/h. There does not seem to be any noise at really slow speeds. This noise is only when turning right and does not happen when going straight or turning left, it almost sounds like the normal drivetrain noise just increases a lot when turning right
04 Touareg/V8/full load/Air Ride/Nav/55k
04vwtouaregv8 is offline
post #2 of 8 Old 10-30-2012 Thread Starter
has anyone else experienced this problem?
post #3 of 8 Old 10-30-2012
Are all 4 tyres identical make, model, tread pattern and with similar tread depths?
Otherwise stepper motor?
post #4 of 8 Old 10-30-2012 Thread Starter
All tires are identical and worn all the same, guess I will try the stepper motor, that is a simple job right, that's what I got from reading on here
post #5 of 8 Old 10-30-2012
Only turn left.......
2004 V8 / Air suspension / lowering module / 4 zone climate / Nappa leather / Xenon lights / sunroof / HR tow / rear tub and cargo barrier and mats / rear diff lock / 19 summer and 18 inch winter wheels / racks / Porsche muffler with V10 tips / 120,000 km's and spotless . ECU upgrade next.
Tooraktractor is offline
post #6 of 8 Old 05-11-2016
My 2014 TDI-Egg has done the exact same thing since day 1 (brand new)! It almost feels as if maybe the bearing(s) might have been defective from the manufacturer. I've taken it to VW for this specific issue 2X and both times they were unable to recreate the problem. Since then, I've noticed it is starting to occur more often than it did when I first got it. I first noticed it every time I turn right to go out of my neighborhood and drive through the exit lift gates. This RH turn and exit is on a slight (maybe 15 degree) incline, which might explain how it's only happening then?
Florida_PhunGuy is offline
post #7 of 8 Old 05-11-2016
Philth's Avatar
I would take a look at the wheel bearing.
Philth is offline
post #8 of 8 Old 05-12-2016
I think I am correct in saying that if it is a wheel bearing and the noise happens when you are turning right, then it is the left bearing that is the problem as it loads up in the turn, and it's vice versa if the noise only happens when turning left.
