no dipstick on 2012 VR6? How to use extractor? - Club Touareg Forums
post #1 of 22 Old 01-27-2015 Thread Starter
Touareg: 2013 V6 FSI
Hi there. The service screen on my Touareg indicates that my oil level is too high. Is there another way to verify this? I read in the manual that there's no dipstick on the VR6. But I wonder if they just capped it and if there's still a place for me to extract some oil if it's overfilled. I'd rather not pull the skid plate and do the drain plug(I may drain too much). Is there a hidden dipstick or place for a dipstick? If not, how do you guys with oil extractors pull the oil from the top of the 3.6L VR6?
Markv77 is offline
post #2 of 22 Old 01-27-2015
Moderator
hedditch's Avatar
If you really don't like your Touareg then use an oil extractor to change the oil.
hedditch is offline
post #3 of 22 Old 01-27-2015 Thread Starter
I don't want to use it to change the oil, I want to fix the fact that the dealer overfilled it. Or at least verify that the digital reading is accurate.
Markv77 is offline
post #4 of 22 Old 01-27-2015
T-Reguan's Avatar
Touareg: 2012 Hybrid
Second Vehicle: 2012 V6 FSI
yes, there is a dipstick cap. If you're facing the engine it should be to your right. Ultimately you can buy a dipstick that fits your model.
T-Reguan is offline
post #5 of 22 Old 01-28-2015 Thread Starter
Many thanks! I'll take a look today.
Markv77 is offline
post #6 of 22 Old 01-28-2015
The TDI engines in 2014's and 2015's don't have the dipstick tube that our 2011 TDI has - we just bought a new 2015 and the same symptom appeared on the service screen with a pleasant sidebar of "Please reduce the amount of oil in the engine" - it does give pause to the notion that it would have been nice to retain the simple dipstick, since you can't be sure if it's slightly overfilled or excessively filled and challenging seal integrity...
The initial fears of a bad head gasket or a bad injector (which could have overfilled the crankcase with anti-freeze or diesel fuel) were assuaged with the removal of the oil fill cap - no white froth or smell of fuel - a good place to look first without the dipstick.
Yesterday was nice and windy 36 degree day - lying on the concrete - pulling the plastic "skidplates" and backing off the drain plug to a slow steady stream - watching the onscreen level and tightening the plug when it dropped - drained about a pint. My guess is that mechanics get confused about the capacity with liters and quarts - the parts department guy clued me in on this several years back by saying that I would need 9 liters to refill the crankcase on the 2011 TDI - I didn't argue and bought 8 liters - its capacity - or 8.5 quarts.
Bob W is offline
post #7 of 22 Old 01-28-2015
pjod's Avatar
Touareg: 2009 V6 TDI
Mark
Presumably you got your dealer to fill the oil on the last service. Hopefully this has just happened (or have you been driving around with the warning on for some time?).
Why not get the dealer to extract the excess oil and get the correct fill. That is what they should have done in the first place. Also good to get the error noted/recorded, in case there is an issue caused by this down the track. Hope there are not problems for you, but to be on the safe side make sure there is a record of it, and how much the overfill was.
PJOD
V6 TDi 2009 Campanelle White with spare wheel carrier, sun roof, tow package and factory fitted privacy glass
pjod is offline
post #8 of 22 Old 01-28-2015 Thread Starter
pjod, good call. Having them correct the issue is a great idea in case I have issues with the cat or o2 sensors down the road. I bought the car in December, so it's been about a month. I just noticed the oil issue once I started tinkering with the car's computer(?) in the garage. I hadn't looked under the service menu until now.
Markv77 is offline
post #9 of 22 Old 01-28-2015
T-Reguan's Avatar
on 2014-15 the dipstick tube is hidden under the plastic cover.
T-Reguan is offline
post #10 of 22 Old 01-28-2015
T-Reguan's Avatar
V6 FSI. Black tube behind the alternator.
T-Reguan is offline
